62 rear axle stubborn wheel stud removal
Old 10-21-2018, 06:40 PM
Jermo
Jermo's Avatar
Default 62 rear axle stubborn wheel stud removal
Hello All,
I broke a rear axle wheel stud. This stubborn stud will not remove, I have tried penetrating oil and hitting it with a hammer (No Luck) I tried heating it up and hitting it with a hammer(still no luck). Do I need to pull the axle and have it pressed off? Never had one so stubborn.
Any advice will be greatly appreciated.
Thanks Jerry
Old 10-21-2018, 07:02 PM
Vette5311
Vette5311's Avatar
Received 1,255 Likes on 838 Posts
Default Yes
Put the hammer down and pull the axle for the press!
Jermo (10-21-2018)
Old 10-21-2018, 07:25 PM
champs65
champs65's Avatar
Few blips with an air chisel should knock it out.
Jermo (10-21-2018)
Old 10-21-2018, 07:47 PM
Vette5311
Vette5311's Avatar
Hitting a rear axle bearing sideways is never a good thing. They are not made for side load.
Jermo (10-21-2018)
Old 10-21-2018, 07:52 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
AND, believe it or not, you can bend that flange....
Bill
Jermo (10-21-2018)
Drothgeb
Drothgeb's Avatar
I agree with the guys above, never use a hammer to drive out studs, use an air hammer instead. Or, you can do like I am, and replace the whole axle with new ones that have screw in studs.
Jermo (10-21-2018)
Old 10-21-2018, 07:56 PM
1snake
1snake's Avatar
Bill
Properly support the flange and use a press to remove AND install the new studs. That's the only way to do it correctly.
Jermo (10-21-2018)
Old 10-21-2018, 10:25 PM
Jermo
Jermo's Avatar
Thank You All, I guess I'll be pulling the axle, might as well change out both seals while I have it apart
Old 10-21-2018, 10:29 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
if you've whaled on it with a big hammer, I suggest you check the trueness with a dial indicator before pulling the axle….
Bill
Old 10-23-2018, 05:02 PM
GTOguy
GTOguy's Avatar
Received 3,443 Likes on 2,113 Posts
Very, very good points. 1. Verify it's still true while it is still in the car. 2. If it is still true, remove and use a press to do the job properly. Studs should really never be done on-car for the reasons already stated. As an emergency repair for a beater, sure. But a classic with original parts? Nah.....
Old 10-23-2018, 09:42 PM
plaidside
plaidside's Avatar
Received 1,126 Likes on 553 Posts
Could someone tack welded the head of the stud to the flange to prevent it from spinning?
Joe
Old 10-25-2018, 02:02 PM
GTOguy
GTOguy's Avatar
Joe
Studs are splined and pressed into the flange so they will not spin.
Old 10-26-2018, 08:42 PM
Jermo
Jermo's Avatar
Yup, pulled the axle and the air chisel did the job, replaced the stud, put the axle back in all good to go
To 62 rear axle stubborn wheel stud removal
Quick Reply: 62 rear axle stubborn wheel stud removal
