[C1] Voltage regulator
Old Oct 25, 2018 | 05:07 PM
mintcondition's Avatar
mintcondition
Default Voltage regulator
Is this original for my 59? Looks like the other number is 7E. If it is bad what are my options if I want to stay original? Thanks
Old Oct 25, 2018 | 07:32 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
Someone else will have to advise as to the significance of the 7E. As to the regulator, if it is bad, you will have to replace it with a good unit. The single/dual element regulator used with alternators from 1963 forward can be purchased today in a solid state version that will accept an original Delco cover. Previous regulators, ones used with generators are the three element variety (voltage regulator, current regulator and cutout) and for which no solid state replacements are currently available, but facsimiles of the original are still made in the USA of all places. But they are not great and an NOS while expensive, will likely last your tenure with the car, unless you are lucky enough to be 21. These are not rebuildable in the sense that they are made to function as new. They were not manufactured to be repairable beyond attempting to clean up the contacts, re-adjust and re-finish the cosmetics. It might be asking too much for a genuine NOS 7E! But who knows....
Dan
Old Oct 25, 2018 | 08:44 PM
65GGvert's Avatar
65GGvert
7E should be May 57 (or 67).
Old Oct 27, 2018 | 10:57 AM
C.T.'s Avatar
C.T.
According to some old John Pirkle info, the 'E' designates units from 1962 and later, so the 7E indicates '67.
Old Oct 27, 2018 | 11:08 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
The 1119000 regulator is for a 25 Amp generator, common on passenger cars, but not used on Corvettes. AFAIK all Corvette generators were 30 Amp units and would have used 1119001 30Amp regulators.
Old Oct 27, 2018 | 11:45 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
C1s have both 30 and 35 amp generators in the later years.
Old Oct 27, 2018 | 04:24 PM
jim lockwood
I've known for some time that the later solid axle Vettes used the 1119002 regulator and I figured the matching generators were 35 Amp models. Thanks for the confirmation.
Old Oct 27, 2018 | 09:10 PM
62corvette's Avatar
62corvette
That information from John Pirkle references the part number, not the date. The regulator used on 1962 Corvettes was 1119002E. That is per John’s info. (It would then have had a date code like 62A (January) or 62E (May) 1962. In the case of the OP, the 7E is a date code—May of 1957.
Old Oct 28, 2018 | 04:23 AM
scopeli's Avatar
scopeli
Go on ebay and purchase a 1119001 Voltage Regulator.
Old Oct 29, 2018 | 09:57 AM
dplotkin's Avatar
dplotkin
Buying a used mechanical voltage regulator is exactly like buying a used incandescent light bulb. It might work, and it might not.
Dan
Old Oct 29, 2018 | 10:33 AM
C.T.'s Avatar
C.T.
Don't believe so. From John Pirkle directly, in 2011:"The 58-59 model years used 'C', 1960-61 used 'D' and 1962 and later used 'E'. The letter was a series designator indicating 'changes in the internal design of the regulators.'
Old Oct 29, 2018 | 10:39 AM
65GGvert's Avatar
65GGvert
I think we're talking about two different locations of the E. Yours is after the part number, the other is in the date code. See 62corvette's post above.
Old Oct 29, 2018 | 10:51 AM
C.T.'s Avatar
C.T.
Good clarification, thank you.
To Voltage regulator
