[C1] Installing door solenoids on my 57 hood releases
Everything is completed for the installation of the solenoid releases for the hood latches and the wiring of the relays etc. but I have a question for the electrical guys . I have both solenoids fused and wired separately with only one push button controlling both solenoids at the same time . I understand that each solenoid requires a 10 amp fuse but with a 10 amp fuse in each one , it will blow a fuse when both are energized at the same time . Is it under fused ? Should I be running 20 amp. or maybe 15 amp fuses in each one ? I've thoroughly checked all connections and everything seems to be wired correctly with no pinched wires .
I also will be very interested in seeing pictures of your installation and a video if possible.
Also, wondering what is the part number for the items you purchased from Summit Racing? It sounds from your description that they are door solenoids normally used for electrifying door opening locks and you are modifying them to use on the hood latches?
St. Jude Donor '07
Bill
my WAG.... i'm guessing that the latches are exceeding the normal load capacity of the solenoids (doesn't take much to open a door latch...) and therefore are exceeding the normal amperage draw. try increasing the fuse to 15 and 20 as the load should be momentary and not adversely affect the solenoid. if you would have to hold the 'button' in other than momentary the solenoid(s) won't like that and will burn the solenoid and/or wires if it is over fused.
Bill
Bill
St. Jude Donor '07
Thanks for replying Bill . I knew that the original factory springs in the latches were too strong for the solenoids so I added adjustable counter springs on the front tabs of the latches to help lesson the pull for the solenoids . It takes very little pull now for the solenoids . I'm thinking to increase to 15 amp first and go from there but am looking for some different opinions . They are designed to work on 10 amps but that is working with only one solenoid as used in one door but it is activating both solenoids at once .
Bill
Was looking on the Summit website and saw some solenoids that sound like what you may have used based on the price that you mentioned in your original post (AUTSVL75)?
In the Q&A section for this part, there is a the following:
What is the size of fuse to use to protect the circuit on this solenoid?
Asked by STEVEN M on May 05, 2018
A:We suggest using a 40 Amp relay.
Not sure if that helps at all, but thought I would point it out.
Not sure if that helps at all, but thought I would point it out.A:We suggest using a 40 Amp relay.
#33
Success, I went down to the garage this morning and popped a couple 20 amp fuses in and everything is working terrific . A slight touch of the button and the hood pops open . No more dealing with the primitive cable system . I hate cables . I already eliminated the cable system for the wipers by installing a aftermarket system . For anyone wanting to install the solenoid system I will try to post some pictures but if it don't work I can send it along with a wiring schematic through your personal email if you wish . The only thing that I had to overcome to make it work was that the springs in the latches were too strong so I added adjustable compensator springs to help pull the latches . It might have still worked without the compensator springs but it is less strain on the solenoids so they should last longer .
#35
I looked up all of the pictures in my camera ( 17 ) I don't know if that is too many to post on here . If it is , I can just email them to people that are interested in installing the solenoids . Any suggestions ?
#36
Received 5,523 Likes
Send them to me and I’ll post them in this thread so they appear in one place.
I’ll send you a PM with my email address.
bj1k (11-15-2018)
#38
1
2
3
4
5
#40
6
7
8
9
10
