How Bad is it if Spares Not Exactly Same Size?
#41
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
#42
The above picture is my car with a stock 1965 steel wheel with a 205/70 tire in the carrier.
#43
Received 3,443 Likes
You could lower the pressure in the opposite side taller tire to reduce it's rolling diameter and go short, low speed distances. I bought a '66 Coronet years ago for a bargain price because the owner had a flat rear tire on the freeway and bolted on his spare, which was about an inch shorter in height. Car was towed into my shop with burnt up positraction and a sheared roll pin. He had driven it about 20 miles on the highway, though, at highway speeds.That was enough to overheat and take out the posi.
Lotsacubes (11-10-2018)
#44
#45
I've had more flats than I like to remember, the last was this year at Carlisle, I have fixed them all with a plug. I have had flats with new tires, plugged them, and they ran their whole life with a plug, without any issues.
#46
Received 3,043 Likes
St. Jude Donor '05
A modern receptacle is idea over the old cig lighter. Plug kit and small compressor can be had for under $30 at Walmart.
#47
Received 1,283 Likes
I have 205/70R15 tires on my 64. I have a 205/70R15 tire on a 6 inch wide steel wheel in the spare tire carrier.
I made a set of extended length spare tire carrier bolts to accommodate the spare tire.
Don't mess around with off size spares, a 205/70R15 will fit with minor adjustments. The extended length carrier bolts that were available on 64-65 cars (I think) that came with factory knock off wheels will probably work. They are $70 a pair, which is why I made my own (for $12).
#48
63 Corvette with original spare tire carrier but with 65 gold line tire bolts.
I have 205/70/15 Michelin Defenders on front and 215/70/15 on the rear with KO wheels. The spare is a 215/70/15 on a KO wheel with 65 factory style long bolts on the leading edge of carrier support and a 65 carrier bolt at the rear. Tire is aired up to 35 lbs. Spare is in a black plastic bag for easy slide out.
#49
I test fit my '65 tire tub over a 215-70-15 spare to see if it would fit. The tub, not installed at the time, dropped right over the tire. However, I then found that I could not get the tire into the tub if it was installed in the vette - cause - My hanger bolts were too short!
Not wanting to purchase longer bolts, I noted that the threaded portion of the hanger bolts was about an inch long - so my solution was to thread a 7/16 nut (about 1/2 inch thick) onto the bolt to use as a spacer for the hanger bolt re-install to lengthen them a bit. Worked fine!
Also, one more tip - the hanger bolts are a pain to loosen or tighten because there is no hex head on the end. - As a solution, I welded a 7/16 nut on to the end of the bolts to be able to use a socket and wrench (or drill/driver).
Lotsacubes (11-11-2018)
#50
Here is a set of spare tire carrier bolts that I made to accommodate my full size 205/70R15 spare on a 6 inch wheel for my 64.
I got some round bar stock, and threaded the ends. I welded the lug nuts on the bottom. Makes it much easier to get them on and off.
The wide area at the top is a nut that I rounded with a grinder and welded to the rod.
