[C2] Help with parts value estimates
Hey all;
As many of your know, with this recent purchase of the black 65, it came with a ton of parts. I think many would be good for other owners who are looking to fix build or repair, so I'd like to move them along at reasonable prices. Can you help suggest what a reasonable value would be? All this stuff is in great shape.
4:88 gear set
LSD/post unit
black hooker competition headers to black side pipes
Fan
Fan shroud
upper and lower A arms with Ball joints
SPC upper a arms with ball joints
Full Sharkbite rear coil over set up with QA1's
Rear sway bar, shark bite
Rear sway bar stock
Power steering unit - complete but without hydro pump
4 piston front calipers (rotors too if you want them)
Repair Manual (I may just make a couple copies of the whole thing)
I'll dig into more boxes and update more soon..
Thanks!
4:88 gear set
LSD/post unit
Fan
Fan shroud
Rear sway bar stock
Thanks!
Received 5,009 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
4:88's? Damn!
Yea... 4.88's...... Either the car was a drag car at one point (cause it also had a 4 speed in it) or the PO was setting it up for the next gen 8 speed with 2 or 3 OD ratios....
As an old guy I sometimes forget about today's overdrive options. Running straight 4:88"s in my day was only meant for one purpose!
Like the time I came home with G70 tires on the rear of my '67. Explained to my parents it was for better handling and safety. At the time I thought they bought the explanation, but looking back my Dad was no dummy. I'm sure he figured it out, especially since I only had them on the back! (by today's standards those would be narrow tires, but back then they were pretty wide.)
4:88's were for sissys....I ran 6:14's in my 67' Camaro....a little tough for normal street driving but made lots of $$$ late at night....those gears and a nasty Small Block....they never knew what hit them...
Good Dad to have.
Larry
Received 5,547 Likes
I’ll bet dad also knew that skinny tires get better traction in snow, but let that go also! My kind of dad.
I know we are way way off topic here..... But, my dad started us driving in the winter and only during snow storms...... He insisted that we learn to drive only on the worst of days.....
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
Hey all;
4:88 gear set
LSD/post unit
Fan
Fan shroud
Rear sway bar stock
Thanks!
4:88 gear set
LSD/post unit
Fan
Fan shroud
Rear sway bar stock
Thanks!
Side pipes used are probably $500-700 if in good condition.
4.88s probably $150-200
I don't know about the posi and it is hard to determine it's condition without taking it apart to look at the clutches.
