One man brake bleeding
Old 11-10-2018, 01:00 PM
GTOguy
GTOguy's Avatar
Received 3,443 Likes on 2,113 Posts
Gravity has always worked for me,just takes a bit of patience. Grab a cup of coffee and let it happen. I like the camera idea....I don;t have one, but it would be a def. timesaver. Great for checking brake lights, turn signals, spark, you name it. Great idea. And some of us don't need a camera to check our prostate....our head is already up our A$$! Again, cool idea, Frank, and the sign of a flexible/ active mind.
Old 11-10-2018, 01:07 PM
benrep
benrep's Avatar
2023 C1 of the Year Finalist - Modified
Good Idea. I noticed your fluid looks pretty dark. The goal should be not to just get the air out but to replace the brake fluid. I bleed just like you do but into a larger container. I then open the bleeder and count short 2" strokes (long strokes put the master cup into unused territory which if rusty can hurt the cup), say eight to ten pumps and check reservoir level. I experiment to see how many pumps take it to a comfortable level (not too low) Fill reservoir and repeat. If done a few times for each wheel almost all brake fluid will be changed and the system will last much longer. I do all of mine at least every three years. The only way most cylinders fail is because of rust and corrosion. Brake fluid is hygroscopic (absorbs water), flushing often can avoid the problems. The beauty of going for the flush, is when you are done you know the air is out, no need to look for bubbles.
Old 11-10-2018, 01:10 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Precisely what I did. All the old fluid got purged which is why I did a 4 wheel bleed instead of just the failed wheel cylinder as some of the “short cut” crowd suggested. The camera let me see when the fresh fluid started to appear at each wheel.
Corvettes have two speeds: fast and half-assed.
Old 11-10-2018, 01:23 PM
tuxnharley
Support Corvetteforum!
tuxnharley's Avatar
Received 1,937 Likes on 1,183 Posts
Originally Posted by Frankie the Fink
And you can do a self-exam to see if your prostate is enlarged.
High tech equipment - sounds appropriate for the so called “digital” exam....... those who have been there/done that will understand the reference!
Old 11-10-2018, 01:29 PM
benrep
benrep's Avatar
Smart man!
Old 11-10-2018, 01:35 PM
tuxnharley
tuxnharley's Avatar
Yup, one definitely has to be flexible to achive that position. I believe the technical term for it is “a severe case of crainial - rectal inversion”.
Old 11-10-2018, 01:39 PM
Brian VH McHale
Brian VH McHale's Avatar
I prefer the vacuum method.
https://jet.com/product/Neiko-Automo...UaAlYNEALw_wcB
tuxnharley
tuxnharley's Avatar
Some of you might want to try just using DOT 5 silicon based brake fluid in the first place- that would eliminate most of these problems - and discussion. IMHO THAT is the smart move.
Old 11-10-2018, 01:53 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Yep! That's been my experience.
Old 11-10-2018, 02:03 PM
jasonsamara
jasonsamara's Avatar
Why didn’t you just have the little wife help you?
Old 11-10-2018, 02:16 PM
MikeM
MikeM's Avatar
Likely because she told him what he could do with his short leg jokes! Maybe she runs the show around there?
Old 11-10-2018, 02:42 PM
GTOguy
GTOguy's Avatar
My cars will see DOT 5 whey they pry my cold dead hands from the shifter. Not a minute earlier.
Old 11-10-2018, 03:43 PM
  #33
RatDog
RatDog's Avatar
Received 1,581 Likes on 818 Posts
St. Jude Donor '20-'21-'22-'23-'24
And just wait until you get a prostate biopsy. I’ve had two. You get to choose between having it in the exam room or under sedation in the hospital. Didn’t take me long to decide.
Old 11-10-2018, 03:45 PM
  #34
tuxnharley
tuxnharley's Avatar
Wow- your choice, of course. Me - I’ve been using it for 25+ years with great success, no problems. Your opinion may vary.
Old 11-10-2018, 03:50 PM
  #35
tuxnharley
tuxnharley's Avatar
Been there, done that. Two biopsies, external beam radiation treatment. Caught it early!!
Old 11-10-2018, 03:57 PM
  #36
Frankie the Fink
Army
I've had two as well....no sedation and a rough couple of painful days afterwards...both negative thank goodness....
Old 11-10-2018, 04:00 PM
  #37
Frankie the Fink
Army
I just stay away from the "5" fluids, both DOT-5 and GL-5...
I don't care who touts what about their benefits and how harmless they are....its just not worth it whether the pros and cons are fact OR fiction...
To One man brake bleeding
Old 11-10-2018, 04:03 PM
  #38
Frankie the Fink
Army
Originally Posted by AZDoug
That is one use that absolutely never crossed my mind.
I have similar but self contained gizmo i got from harbor freight. Surprisingly, it works fairly well and hasn't broken yet. I have found several uses for it auto and home related. It does have built in light so i suppose you could use it for your application also.
Doug
The advantage of the Aardvark is the camera can be 10-20 feet from your smartphone and so you can place it somewhere in a fixed location and view it remotely - even works to tell if that glove box light stays on when you close the door.
Old 11-10-2018, 04:07 PM
  #39
MikeM
MikeM's Avatar
Kiss
Old 11-10-2018, 04:10 PM
  #40
Frankie the Fink
Army
Th 80s are calling Mike - they want your flip-phone back
Quick Reply: One man brake bleeding
