Ethanol Free 87 Octane vs. Premium 93 Octane?
#41
I also live in NC and I am used to the taxes and do not get all worried about it...because it is what it is and I am not moving a cross the border to SC to save money and THEN have to commute to work every day. It is like gas is cheaper across the border in SC but it is pointless to drive there to fill up the tank and then drive back.
Getting back to the fuel octane/ethanol issue...
I have customers who have some serious engines that they feel that they need a high octane fuel and some of them buy it at the small airports and use it. While others order a drum of CAM2 or what ever and use it. Due to these cars are not daily drivers but are enjoyed on a regular basis... the cost is not an issue in order to keep that prize winning stallion running correctly
I have other customers who want me to back down the timing a few degrees and they can live with that due to they are not trying to be the fastest car on the road.
DUB
DUB
#42
Received 1,843 Likes
Dub:
In your area, do you hear many complaints about fuel perc or other rough running engine complaints due to gasoline? I don't read much about it here from your area compared to the Gulf Coast.
Just curious.
Just curious.
#43
Received 2,339 Likes
Rec90 is the equivalent of 90 octane marine use fuel, and illegal to use on public roads in California because it's cost does not include the $0.30/gallon excise tax for "transportation improvement" funding and loan interest service funding from transportation funds previously borrowed by the state and redirected into the general fund. Since Prop 6 failed a yes vote, the excise tax on road fuels will raise to $0.47/gallon in July 2019. Race fuel and Aviation fuel have similar exclusions for the excise tax burden, and similar legal prohibitions for on-highway use in California.
#45
Received 3,443 Likes
In California I have noticed that I get percolation issues with my '61 Corvette and my two GTO's to some degree with heat soak. I never used to get it with straight gas. Also, the new fuel loses its octane rating after about a year or so. Previously, I have run straight gas that sat in a car for 4 years or so without detonation issues. Also, fuel economy is less with the ethanol-laced fuel. Other than decreased fuel economy, it seems to work fine in my carbureted '83 Toyota and my motorcycles.
#47
Received 1,283 Likes
I started out with 93 octane with ethanol in my 64.
I have since switched to 93 octane no ethanol, which is available in a 3 or 4 places in the local Huntsville area. I did notice a difference in the way the car ran, or at least I felt like there was a difference.
I am going to try a tank of 100 octane no ethanol aviation fuel and see if that makes any difference. I don't really expect it to on a 300 hp engine, and it is not cheap, but I am curious.
And I will have to buy it at the airport and put it in 5 gallon gas cans, since I cannot legally pump it into a car.
One of my local Corvette friends uses 100 octane aviation fuel exclusively in all of his collector cars, including a couple of fuelie Corvettes.
Regarding the discussions about ethanol gas and fuel injected Corvettes, my friend has a 1965 FI car. He puts 100 octane no ethanol aviation fuel in it.
He told me that he has had starting / running issues on a couple of occasions when the ambient temperature was very high (temp in the high 90s, heat index well over 100, very high humidity).
This has only happened a couple of times; most of the time there are no issues.
#48
Save your money and run the lowest octane pump fuel the engine will tolerate. My 300hp engine runs good on 89 octane.
#49
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
#50
#52
IMO
I think there are some missing details in your post. Such as how often you drive the car, amount of miles or tanks of fuel do you use in a year and type of driving, engine mods and other variables...
If your car sits for any length of time than ethanol isn't a good choice. I will pay the price for 110 racing fuel, ($9 a gallon), knowing I only have to fill 4-5 times a year. That's about 1000 miles or $600 for me. I can let the car sit a few weeks and hit the key with no doubt it starts and will operate perfect for me regardless how hot it is outside. I have yet to have any issues in 2 years. Even after 4 months in winter storage.
I have had to use ethanol a few times with mixed results. Yes it was cheaper but seemed to use more fuel. Less mpg. My fellow coworkers agree with my opinion too.
To me it isn't worth it and avoid ethanol. And I live in corn country.
#53
IMO
#57
JV04, After reading your original post again, you were asking about trying 93 WITH ETHANOL. I will state it isn't the octane, its the garage in the fuel or what isn't. I found racing gas with no ethanol is the only thing my 61 injection likes. It is stable and stores well. There are many studies and stories on the web about the negatives of using fuel with ethanol. I wish I had better luck with it and my family and many friends don't use it here in Nebraska either. But many do in their everyday drivers with no issues. I am lucky I have a choice. I will say this too I get 3/4 mile more per gallon in my new truck using 92 vs. 87 both no E. Good luck.
#58
The only problem I've had with ethanol is in small engines and two-strokes....
My 1996 SeaDoo jet ski had the fuel lines turn into gummy bears from the stuff...
Nearly all rebuilt components, fuel pumps, carbs have ethanol resistant gaskets and soft parts now...
I ran 87 octane ethanol laced gas in my dual-quad 61 for 10 years and nary an issue...
#59
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
My experience is that Ethanol becomes a problem in engines that don’t get used a lot and don’t have a high turnover of fuel.
The check engine light light kept coming on in my wife’s 2012 Grand Sport. The car only has 9,000 miles on it. The Chevy service manager told her she needed to either drive her car more more to rotate the gas out or use non-Ethanol. She started using non-Ethanol except for fill-ups when she knew she was going to use up a tank quickly. No more check engine light.
Steve
Steve
#60
Any way going back to the gas issue OP if you can get Ethanol free gas and it does not ping I would stay with that. Ethanol gas has the propensity to form water which accumulates in the bottom of your gas tank. That is if the gas stays in the tank for a long time. Daily user you do not have to worry.
I believe you have it backwards. Straight gasoline will allow water to settle out to the bottom of your tank. Ethanol gasoline tends to keep it in suspension and pull it through to the point of no water left. That is, unless you leave your gas cap off the tank but either way, water is bad for your fuel system.
Ethanol also does bad things to flexible (rubber) parts in the fuel system. I would try to avoid ethanol at all times in anything with a mechanical fuel pump, and I'd avoid it with most mechanical fuel injection systems as well. 10% ethanol blends will absolutely cause damage to mechanical fuel pumps and any type of flexible membranes in the fuel system.
As for octane, use enough that your engine doesn't ping, even under load at wide throttle openings. I also live in Georgia (northern extremes of "metro Atlanta" area), and ethanol free 90 is pretty widely available near the lakes where boaters use it in their older outboards. 93 is sometimes available, and if it's in a separate pump or separate hose from the ethanol blends, it's usually actually ethanol free.
Beware "ethanol free" that's from the same hoses as ethanol blends. I've tested some and found them to have up to the 10% ethanol that you'd expect in regular (or premium) gasoline.
If you aren't sure of your supplier, it's easy to test for the presence of ethanol. Get a glass jar or bottle, put a small amount of water in the bottom, mark the bottle/jar with a sharpie, or scribe a line with a sharp scribe. Add your gasoline sample. Put the lid on and shake the sample vigorously for 30 seconds or so. Let the jar/bottle sit for 30 minutes to an hour, and note where the line separating the water at the bottom from the gasoline at the top is. For ethanol free gas, there will only be the water you put in at the start at the bottom, right up to the line you marked/scribed. For ethanol blends, the stuff that settles at the bottom will be the water and the ethanol from the fuel blend, and the separation line will be higher in the jar/bottle than your marked line. If you measure carefully, you can actually tell how much ethanol there was in your sample, but the important thing for older vehicles with mechanical fuel pumps or mechanical injection systems is the presence of ethanol. To avoid problems, you really want to avoid ethanol if you can.
Rdelvalle (11-14-2018)
