TRW engine parts numbers
Received 1,533 Likes
Decided to freshen up the heads on R66. I have a few new parts left from our racing days. I found the new springs, valves, and pushrods. I also found rings and bearings but am not sure of the fit as I cannot find a reliable source for the part numbers. I want to be ready should I pull the heads and find some cylinder wear or scoring that I don't like.
Then found these TRW rod and main bearings:
MS1808P (3 sets) main bearings - I believe they fit the 61 thru 66 small journal crank - 2.30"
MS909P (1set) main bearings - I believe they fit the 67 and up small blocks - 2.45"
CB663P1 (1set) rod bearings - I believe they fit the 61 thru 66 small journal crank - 2.0"
Anyone have an old TRW parts catalog that they could verify these parts for me?
Ron
Ron
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
If you do a Google search for each number it tells what they fit.
R66 (11-16-2018)
Tried that and the eBay posts were all over the place and don't know that I trust them. A couple of parts resellers had the MS1808P main bearings fitting everything from 57 thru 89. I think I have it right, but If all else fails, I will remove a set from the packaging and measure the ID, but was hoping someone might have a reliable source. It looks like Mahle bought out just about everyone. Just being lazy I guess.
I have a TRW catalog from the 70s. I will get it out and confirm your findings, but I DO believe you have it right.
R66 (11-16-2018)
The MS1808P are main bearings for small journal cranks, they'll work for 265, 283, and 327.
The MS909P are 350 main bearings they will also work for a large journal 327 or a 302 if you happen to have a few of them laying around or a 307.
the CB663P1 are .001" under rod bearings for a large journal crank. They are for tightening up the clearance if it's a little loose. They also fit the LS family of engines, i.e. Ls1-LS7
R66 (11-16-2018)
Well, I hung on to these for years. I guess I have saved a little money if I need main bearings, but still will have to buy rod bearings if I need to go any farther than a valve job. Then again, while I have it down, why not do it all, need or not. I've got rings, roller timing chain, oil pump, and gaskets, so it is a little expense thing. The part I hate is pulling the engine and trans again. Got 4 months, no hurry.
Thanks again Gentlemen.
PS: Now I can justify the 8x20 Sea Land storage to my wife. Won't tell her how inexpensive they are.
