[C1] 1960 Corvette lower heat shielding?
Does the '60 model use any form of heat shielding for the ignition wiring that runs behind the exhaust manifolds?? I'm not speaking of the EM shielding... I'm asking about HEAT shielding such as the '57 Corvette used??
Pro Mechanic
Received 1,302 Likes
2023 C1 of the Year Finalist - Modified
My '60 didn't have any (doesn't mean it never did) but I had to make shielding between the middle 4 plugs and the exhaust manifold because the spark plug boots kept melting.
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
Do you have a picture of this for 1957? OR a link to where it can be purchased?
Yes, all the parts houses have these parts for '56-57 Corvettes/passenger cars.. I'm trying to determine if '58-62 Corvettes used anything like this for a similar purpose?Spark Plug Wire "U" Heat Shield Kit (Banana shields or 'boomerang' shields) protect park plug wiring from exhaust manifold heat...Paragon Number: 3266K
GM Part Number:
Spark plug wire lower “U” heat shield kit, includes (2) shields and (8) grommets.
Years: 1956 - 1957
Condition: New
Packaging: Kit
Type: Stock
Price: $31.00
GM Part Number:
Years: 1956 - 1957
Condition: New
Packaging: Kit
Type: Stock
Price: $31.00
GM Part Number:
Years: 1956 - 1957
Condition: New
Packaging: Kit
Type: Stock
Price: $31.00
GM Part Number:
Years: 1956 - 1957
Condition: New
Packaging: Kit
Type: Stock
Price: $31.00
Although these parts are referred to above as HEAT shields I think they are actually just radio shielding as they contain the plug wires encased and bolted to the block and would be as hot or hotter then if they were exposed to the air.
Maybe someone can clear up this confusion?
Those are the ones that go over the top of the spark plugs and plug wire boot. The others shown above are for the plug wires BEFORE they reach that point. The original plug wire sets for these cars are very long and run down the back of the engine under the shielding top and side pieces and then route through the other pieces shown above that bolt to the block.
Bama,
57’s had the boomerang shields, 60’s did not. 60’s used a clip on each side that attached to an oil pan bolt. That kept the lower portion of the wires against the block and away from the manifolds. Then, on the same 1/4x20 bolts that hold the 4 brackets (pictured) to the block, there are small 3-fingered clips that also hold the wires to the block and away from the manifolds.
BamaZR1 (11-20-2018)
First kit is heat shield only. Second is ignition shield w/heat shields included. The third link was only used on 56/57
https://www.corvettecentral.com/c3-68-82/ignition-distributor/spark-plug-wires/58-69-spark-plug-heat-shield-kit-283-327-350-471156?returnurl=%2fsearch%3fcurrentsear chcategoryid%3d%26q%3dheat%2bshields%26y ears%3d1956%250a1957%250a1958%250a1959%2 50a1960%250a1961%26count%3d9
https://www.ecklerscorvette.com/corvette-ignition-shielding-kit-with-fuel-injection-1960.html
Sorry for the added post. For some reason I'm really having a tough time posting links today. This one is what the 56/57 cars used (heat shield).
https://www.corvettecentral.com/c1-5...eld-kit-471155
68hemi (11-20-2018)
Bama,
Gary
I am a little confused by both your 1st post and this one. I don't know what EM shielding is? The shielding for RF to shield the radio from ignition noise is the only shielding I am aware of. I don't know of any HEAT shielding on these cars. I thought maybe I was missing something on my 57 but the parts you have shown look to be part of the ignition shielding that bolt to the block that I recall on several of the old Corvettes I own.
Actually the lower banana/boomerang shields (for '56-57) were actually used on metal passenger cars also, and were for 'heat shielding' as opposed to RF/EM shielding (although obviously they would serve to help that function as well). The purpose was to keep the wires from touching the HOTTER exhaust manifolds (read 62Corvette's post on this topic)...
68hemi (11-20-2018)
thanks guys
Received 1,857 Likes
Here are the original '56-'57 (ONLY) Corvette lower heat shields for the spark plug wires:
I'm familiar with the '56-57 lower heat shielding, but I'd LOVE to see a similar photo for the small bits installed which held the wires away from the exhaust manifold/pipe on '58-60 models. I've ordered the parts (per Paragon) but haven't seen a photo of them installed... anyone?
