Pillar picture
Pillar picture
Does anyone have a picture of their pillar before they put the weatherstripping on? My inside molding, 65 roadster, won't fit over the windshield frame correctly.
Thanks,
Dex.
Thanks,
Dex.
Pillar garnish fit
Is this what you need?
need? Sorry about the large size but I coudn't figure out how to make them smaller. If you need more email me at rccarson53@gmail.com.
RC
RC
Received 2,827 Likes
Crowd Plow For Now
Look in AIM and weatherstripping. I believe that will cover it as the painted part is where the WS will attach if I remember right
Those are a little tricky to install. You need to push it over the lip first, and then roll it forward, while lifting up on the outside trim with a screwdriver or nylon stick. At the same time, you'll be pushing down on the inside trim to get it under the outside trim (at the top). If you're trying to install it at the top first, it will never go in. Be careful that you don't scratch your dashpad, or lower inside windshield trim.
Thanks Guys! Here's a couple pictures. When I slide the inner trim over the lip and work it up, it sticks above the outer trim.
Second picture.
Thanks,
Dex.
Thanks,
Dex.
Mike's suggestion worked perfectly....after I got passed the part of worrying about denting the outer molding by prying up on it.
Thanks,
Dex.
Thanks,
Dex.
