66 big block 425hp
66 big block 425hp
I have a oil leak that drips off of the starter, I pulled the starter off and the bolt closest to the block was soaked with oil, does anyone know if that bolt is open to the inside of the block and causing oil to run down the threads and onto the starter and then drip onto the ground. When I reinstalled the starter I used a permatex thread sealer on both the starter bolts so hopefully that will solve the leak.
Thanks D Sperle
Thanks D Sperle
Received 6,929 Likes
2015 C2 of Year Finalist
I would look the valve covers first, they are known to leak and drip oil down and drive you crazy
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Those bolts do not go to oil. It would be best to not use anything on threads.....they help provide a ground for it electrically...but as long as it's tight against block it will be OK.
That oil is coming from above....intake, valve covers etc.
JIM
JIM
well don't know what to say, but since I used the thread sealer on the 2 starter bolts I have driven the car close to 200 hundred miles on 5 different
occasions and guess what, it's dry as a bone, 0 leaks, my starter bolts must go to oil, because that's all I did and starter is dry no leaks, who knows how
thinks were machined in the 60s or how consistent the quality was back then.
D.Sperle
D.Sperle
