C2 Front brake calipers....what am I missing here??? - Page 4 - CorvetteForum - Chevrolet Corvette Forum Discussion
Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Reload this Page >
[C2] Front brake calipers....what am I missing here???
Old 11-29-2018, 11:31 AM
  #61
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Originally Posted by Factoid View Post
Greg, I think you just determined that your bracket is the guilty party.
I dont disagree. Its odd though that both brackets appear to be tweaked in the same direction. Im going to see if I can track down some original brackets on ebay as opposed to these reproductions
FLYNAVY30 is offline
Old 11-29-2018, 12:01 PM
  #62
67vetteal
CF Senior Member
67vetteal's Avatar
Your patience with this problem is a great asset. Have you researched the parts list thoroughly for accuracy? This situation is very odd. There is something mismatched and finding it is the clue to correcting it. JMHO, Al W.
67vetteal is offline
Old 11-29-2018, 12:45 PM
  #63
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Al, I've gone back and forth with Dan at Van Steel numerous times over the past 48 hours to ensure I have all the correct components. He's as confused as I am at this point. They're in the process of rebuilding a disc brake chassis this week....he's going to compare that build to my parts list to see if there is something we're all missing here.
As a last ditch effort this weekend, I'm going to strip everything down to the bare spindle, and document the reassembly process with individual photos of every single component and post them in order on here. Hopefully someone will catch something we've all missed. Beyond that, all I can think of is that I've got a pair of tweaked caliper mounting brackets.
Old 11-29-2018, 01:54 PM
  #64
Grampy
CF Senior Member
You don't have to pull the disc, I just slid drill bits between the disc and bolt as a gage for the gap. Just to get in the ball park. Also I don't have dust shields so your gap should be a little smaller than mine.
Grampy is offline
Old 11-29-2018, 02:18 PM
  #65
Pop Chevy
CF Senior Member
Pop Chevy's Avatar
All you really have to do is space your rotors out.b For the heck of it pull the rotor and put some .060 washers behind it on the studs and try it.
Pop Chevy is offline
Old 11-29-2018, 05:31 PM
  #66
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
That will definitely work, but its somewhat of a Band-Aid solution. It would also reduce the amount of thread available on the studs, and push the wheels further out, thus effectively changing the backspacing. All things I'm not interested in doing. Dealing with 95% OEM style parts here, this shouldn't be rocket science. I'll be curious to see what Dan comes up with in another day or so.
Old 11-29-2018, 06:34 PM
  #67
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Just stuck a stack of feel gauges in there and then mic'd them out....I've got .1965 with the dust shield installed and my dust shield is just over a tenth....so that checks out.
Old 11-29-2018, 08:07 PM
  #68
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
pulled the trigger on a set of NOS 65-67 caliper brackets on eBay. For 80 bucks shipped, I figured it was worth a roll of the dice. I also downloaded the specs on the calipers from Wilwood's website and every measurement is spot on within thousands. At this point, the only variable left is the caliper bracket....heres hoping
Old 11-29-2018, 09:57 PM
  #69
Saddletan
CF Senior Member
Saddletan's Avatar
The UPS driver threw my right front Vansteel assembly off his truck. The other one landed on top of that box. The one that hit the pavement had a bent caliper bracket. Van steel replaced the whole assembly and paid for shipping. The spindle brake caliper assembly is quite heavy. It dug it’s way through the spray-in foam packing material.
Saddletan is offline
Old 11-30-2018, 09:02 PM
  #70
USMC 0802
CF Senior Member
Support Corvetteforum!
USMC 0802's Avatar
Good luck, Greg.
USMC 0802 is offline
Old 11-30-2018, 09:15 PM
  #71
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Originally Posted by USMC 0802 View Post
Good luck, Greg.
Gonna get to the bottom of this....one way or the other!!
The Following User Says Thank You to FLYNAVY30 For This Useful Post:
USMC 0802 (11-30-2018)
Old 12-05-2018, 03:09 PM
  #72
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Finally have front brakes!!! Ended up being a combo of crappy quality reproduction caliper brackets and the stick on backing plate on the Wilwood pads makeing them a solid tenth thicker than factory pads.
Old 12-05-2018, 03:21 PM
  #73
Tom Austin
CF Senior Member
Tom Austin's Avatar
Great news Greg! I just love a "happy ending"!😎
Tom Austin is offline
The Following User Says Thank You to Tom Austin For This Useful Post:
FLYNAVY30 (12-05-2018)
Old 12-05-2018, 03:27 PM
  #74
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Yea, that was a real hassle for what should be a fairly simple "upgrade". I was shocked how far out the reproduction caliper brackets were vs. the OEMs.....$80 bucks well spent. Apparently the stock pad thickness is .505 in. With the backing on the Wilwood pads, they measured out at .521. Once you pull the backing off, they measured at .491 and slipped right in. The caliper still isn't perfectly centered over the rotor, its still about a tenth towards the inside, but lets be serious, nothing on these cars is within a tenth of an inch of perfect. Either way, everything fits and the discs don't drag....moving on!
Old 12-05-2018, 03:41 PM
  #75
Factoid
CF Senior Member
Factoid's Avatar
Congratulations, Greg, that is outstanding!
Factoid is offline
The Following User Says Thank You to Factoid For This Useful Post:
Old 12-05-2018, 04:10 PM
  #76
Grampy
CF Senior Member
We shall not just endure, we shall prevail. Good on you
Grampy is offline
The Following User Says Thank You to Grampy For This Useful Post:
Old 12-05-2018, 05:15 PM
  #77
Viet Nam Vett
Everthing ..All The Time
Viet Nam Vett's Avatar
2015 C2 of Year
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
Great ending to a Tough thread. Well Done CF..!!
Viet Nam Vett is offline
Old 12-06-2018, 10:34 AM
  #78
69ttop502
CF Senior Member
69ttop502's Avatar
Great deal and thanks for updating. Good to know on the repro brackets. Is Van Steel going to do something about the brackets? Hopefully they will. Nothing worse than buying new parts that don’t work.
Bill
69ttop502 is offline
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
