Positraction In A '62 340HP
I'm curious to know if the rear end in a '62 C1 with 340HP engine and a 4sp was always a 4.11 with Positaction?
Bob
Bob
Received 1,973 Likes
The standard axle ratio for '62 340/360 HP engines with the base three-speed manual trans was 3.36 with an open differential. Positraction was optional, but there were no other available axle ratios with the three-speed manual trans.
If ordered with a four-speed the standard axle was 3.70, open diff., but Positraction was an option. In addition, five other ratios were available: 3.08, 3.36, 3.55, 4.11, and 4.56, and they were only available with Positraction.
Positraction was ordered on all but about 300 '62 jobs, and 4.11/Positraction was probably the most popular axle ratio with SHP/FI engines, but I'm not aware that the axle ratio count was ever published... just the number of Positraction options.
Duke
Duke
The rear end is definitely not Positracton, but I have a slight suspicion it may be a 4.11. It's getting cleaned up now so they can read the tab attached to the diff.
A couple of years ago I bought a C1 third member with the large "P" on it. It had frozen 4.56 gears so I had it cleaned up and changed to 3.55 gears and put it in my '56 Chevy. Should I think of swapping third members? Would it retain "numbers correct" status?
Bob
Bob
Well, from what I've read, my case pictured here is for Positraction gears. I've read the large "P" indicates it is Positraction. I am posting a pic of the case, and a pic of the VIN tag on the steering column. How can this be deciphered?
I am also posting a couple of pics of some brackets that were welded onto the frame and axle housing. For traction bars?
Bob
Bob
Deciphering
Tags
This post caught my eye because the poster who put a pic from another board put up the pic of my 62 frame the day I pulled the body off.
here is what I see .....your car was assembled May 21, 1962, your third member cat number 812 is a posi unit and the aluminum tag on says 411 gears.. what I don't know without looking inside at the ring and assembly would be is it a real 411 posi? The other data point is the cast date is d182 which is April 18, 1962....that is good , now remove grime and rust on the opposite side and look for a stamping that will confirm Corvette and date code
Received 3,766 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Bob
Bob
That casting date on the rearend case is for sure a good date for a 62 Vette (D 18 2 translates to Apr 18, 1962). That tag under the nut at the 2 o:clock position indicates a 4.11 ratio. With the big P on the case, it was for sure (originally) a posi rear. If both axles do not pull together now, then very possibly the clutches are worn out causing it to pull (on one side only) like a non-posi rear.
The VIN's for 1962 were 100001 to 114531. Yours is 111521, indicating your car was the 11,521 Corvette built in 62, meaning yours was about 3,000 cars from the end of 1962 production. Thus, the Apr casting date on that rear is just right for your car (very possibly the original rear).
I have added a 1960 axle housing to my 56 as well as a 60-62 rear sway bar. Also, I have installed aftermarket (Traction Master) traction bars. You can see below what the FACTORY brackets/traction bars look like on 59-62 Vettes as well as the rear sway bar.
To install the NON FACTORY aftermarket traction bars on my 56 (below the leaf springs), longer U-bolts were required.
Great news! Thanks guys. Everything so far is jibing with what the previous owner told me. He did tell me it was a Positraction rear end, and that he thought it was a 4.11 gear ratio because of the high RPM at 60mph (which was 5mph over the speed limit when he was driving it back in the 60's).
I was disappointed when the fab guy doing the restoring underneath told me it was not Positraction, but he was basing it on only one wheel spinning forward. This car has not been run since 1978, and not moved since about '94 so it's very possible the clutch plates are messed up. Should I be considering a complete rear end overhaul, or just flush it and add fresh Posi lube?
I've instructed the fab guy to remove the brackets. What ever they were meant for, I hope I won't need them.
Bob
Bob
Received 1,843 Likes
You left out the important part. What was the other wheel doing while one went forward and was the car in gear or out?
Incidentally, my fab guy is asking me what color of black he should use. Same with the engine bay?
Bob
If you're not going to be spinning the tires, I wouldn't worry too much about the posi traction whether ir worked or not or even if it was there and not working. If the clutches are worn totally worn out, it'll act just like a standard differential.
Seems like your major concern is that big P on the carrier casting?
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
Good questions but I don't have an answer for both as I wasn't there. They are removing the transmission and drive shaft as we speak to clean and repaint. Haven't decided as to how to address the differential problem. I'd rather not have them take it apart, but they may have to. I'm thinking perhaps I should just give it a couple of good flushings and fill it back up with a good Posi lube and drve it a while and see how it works. Should I just pull it and have the whole rear end overhauled?
Bob
Bob
ptjsk (12-08-2018)
I'm not spending $4,000 to have the 327 rebuilt and do a half assed job on the rest of the drive train, please excuse my "French". If I can't get the diff to work as it should, I'm pulling it out and sending to a rear end specialist. Those near me in the South Bay may know of Rear End Specialties. They did a great job on the 'vette Posi I put in my '56 Bel Air.
I didn't mean to emphasize on the large "P". I just remembered reading when I bought one for the Bel Air that the large "P" identified it as a corvette Posi 3rd member. It had frozen 4.56 gears which Specialties removed and replaced with 3.55's. Axles had to be modified to fit.
I am posting another thread with pictures of the under carriage. Looking for much appreciated help on that as well.
Thanks,
Bob
Thanks,
Bob
I didn't mean to emphasize on the large "P". I just remembered reading when I bought one for the Bel Air that the large "P" identified it as a corvette Posi 3rd member]]
hanks,
Bob
hanks,
Bob
You asked for advice but you didn't specifiy whether you wanted half assed advice or expensive advice. My advice was based on your perception of what seemed to be important to you.
$4000 to rebuild that 327 is a lot of money for what?
I don't understand why you think that big "P" means it's a Corvette rear end. It also means it could be a passenger car third member.
Some here have to have the finest and best. Others don't need to spend the big bucks to have a nice car. Please specify in the future. High dollar answers are readiiy found on your copy of the service invoice you just paid for on in books you can buy and read up on. Half assed answers usually come from people that have been around awhile and know what you can do and what you can't. How much you have to spend and how much you can save.
Bob,
If you should have any more questions, I would STRONGLY suggest that you ask them BEFORE throwing a bunch of money into a bottomless hole.
IF, IF, IF, you should decide that you want to have a higher gear ratio in your rearend (for lower rpm and better fuel economy on the hiway), you CANNOT, CANNOT, CANNOT put any 3-series gear set onto the 4-series posi unit in your car (I'm not talking the outer case, I'm talking about the internal posi unit). To switch to a higher gear ratio, such as a 3.55, 3.36, 3.08, it would be necessary to go with a 3-series (internal) posi unit. It's too bad that you are so far away. If you were near Okla City, and had the center section removed from the axle housing, I could take a look at it and go from there.
Oh ya--------------your transmission will be (or should be) a Borg-Warner ALUMINUM case T-10-----------------------THEY WERE NOT PAINTED FROM THE FACTORY, THEY WERE BARE ALUM!!! I would recommend telling them NOT to paint it----------------not even silver!
The machinist gave me an initial quote of $3K-$3.5K for a normal rebuild. It seemed to be in line to me. I've just spent $70K-$80K in restoring a '55 Nomad and it's almost done I don't want to do it again anytime soon.
Bob
Don't take offense my friend. I sincerely appreciate your inputs.
Bob
Bob,
Your advice has been very helpful. The engine is now on it's way to being rebuilt. I'm hoping it will be done by mid January. Now I've got the rest of the drivetrain, suspension, brakes and steering.
Also, how much should I do to the cosmetics of the under carriage of a car I want to look like a survivor on the surface but a well built car as a driver.
Here are some pics of the Under Carriage. I was going to create another thread but I messed it up. Here's some pics.
What color for rear end? Engine bay? Was frame painted?
Bob
Bob,
Fresh pics from Fab guy before it goes into degrease.
PS. The price you were given for a stock rebuild sounded okay if someone else did all the work. Don't know why a guy would need all that hot rod stuff.
