C2 65 Vent Glass Mounting Strips - CorvetteForum - Chevrolet Corvette Forum Discussion
[C2] 65 Vent Glass Mounting Strips
Old 12-05-2018, 06:26 PM
58n65
CF Senior Member
58n65's Avatar
Default 65 Vent Glass Mounting Strips
After placing the mounting strips around the glass, I pushed the glass into the frame. For some reason it does not seem like that should be all that I should have done. Seems like the glass would slide out when the vent is open. Did I miss something or was it really this easy to do?
Thanks,
Dex.
58n65 is offline
Old 12-05-2018, 09:29 PM
Greg
CF Senior Member
Support Corvetteforum!
Greg's Avatar
I have installed these Dex. Should be a pretty snug fit.
Can you pull the glass back out by hand?
If No, all is good. If Yes, there is an issue.
Greg
Greg is offline
Old 12-05-2018, 10:36 PM
58n65
CF Senior Member
58n65's Avatar
Greg
If I pulled real hard then I probably could but it's not easy. If that's all good then all I need to do is trim it.
Thanks,
Dex.
58n65 is offline
Old 12-05-2018, 11:47 PM
Greg
CF Senior Member
Greg's Avatar
Bingo!
Greg is offline
The Following User Says Thank You to Greg For This Useful Post:
58n65 (12-06-2018)
Old 12-06-2018, 05:26 PM
65 Pro Vette
CF Senior Member
65 Pro Vette's Avatar
You will know if the vent window is seated completely in the frame when you go to close it it should fit in the opening perfectly if not it is not all the way back into the stainless steel frame. I use a rubber mallet with the stainless steel frame backed up with a piece of wood. Works every time.
65 Pro Vette is offline
Old 12-06-2018, 11:53 PM
58n65
CF Senior Member
58n65's Avatar
I installed them yesterday and today and I noticed that the glass doesn't quite close all the way. I'll do as you've suggested, when I get some more free time.
Thanks,
Dex.
58n65 is offline
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
