Replaced my original N11 mufflers with new.
My '64 Sting Ray Coupe with L76 was ordered with the N11 off road exhaust. They finally developed rust holes as mufflers always used to. I decided to replace them with the best reproduction mufflers, I could find. After research I found Corvette Central exclusively carries the N11 exhaust with the GM License as Restoration Parts. Out of the box they looked very good, but how they fit and sound is also very important. I got the car up on jack stands and went about removing the old system. The mufflers come welded on to what I used to hear called intermediate pipes, that slip over the pipes that bolt up to the exhaust manifold. Now those pipes still looked perfect so I decided not to replace them. I also ordered 2 new donut gaskets as you need to remove the front pipes to easily install the new rear pipe and muffler assembly. From start to finish took about 3 1/2 hours to lift car, remove old system, install new, and lower car. Very pleased with the result and for $399 not a bad value. The engine is a stock L76 327 solid lifter engine. Here's a short video so you can hear the nice tone.
Finished installation on 1964 Sting Ray
Screen capture from YouTube video produced by Waldron's telling how the mufflers were developed. Search YouTube and you'll easily find it.
The following 3 users liked this post by mjdart:
Received 5,524 Likes
Well done! My ‘64 coupe originally came with the N11 option. Now it has capped cutouts just below the manifolds. What is the difference between the stock exhaust and the N11? Is it simply different mufflers?
On a separate point, looking at how clean the rear of your car is and the relationship between the spare tire tub and rear crossmember, I realize just how twisted my rear crossmember is and that I need to replace it.
Thanks for posting and nice job on the install!
That's a very nice system.. Nice install too .
Received 2,126 Likes
Nice work, looks good and sounds healthy. Dennis
Thanks, I was impressed how the engineers set up the exhaust system giving you to points to adjust the muffler position to get the chrome exhaust tip centered perfectly in the rear hole in the body. Also the clamps between the front exhaust pipe and the intermediate pipe not only clamp tight preventing leaks but they are also used to center the exhaust pipes as they pass through the frame. They hang on the rear transmission bracket which has two wings to accomplish this. I call this elegant engineering, meaning simple, efficient and cost effective. It also allows the end user the ability to take it apart and reassemble without screwing it up!
Chuck Gongloff (12-07-2018)
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
I have the N11 mufflers on my 1957 since I never put the top up on the car but on my 1965 I have the quieter stock mufflers so I can listen to the radio better. The N11’s do sound nice on your beautiful car.
mjdart (12-07-2018)
What really amazed me was when I opened the spare tire carrier to remove it for access (another easy job) that it contained an ancient, but perfect, original looking spare Goodyear Tire (without any air in it). I pumped it up after wiping it down with rubber protectant and it seems fine, I've had the car about 3 years if anyone is wondering.
Looks nice and sounds great. I wonder if any members have tried using band clamps on pipe connections in lieu of crush clamps. It would seem to make disassembly a lot easier if it has to be taken apart to pull a transmission or to remove the mufflers to get to the antenna or something. I have them on the undercar exhaust on my ERA Cobra and use a Walker sealer on the connections. They come apart with a little wiggling and pulling. I wish I had done so on my 67 GTX as working around the exhaust and H-pipe to pull the transmission was a pain.
Guess what I forgot to do when I installed the new components!!! Well, I guess it'll sit in the garage a while longer...lol
marshal135 (12-18-2021)
