Stuck Kingpins
Old 12-12-2018, 01:11 PM
Pop Chevy
Support Corvetteforum!
Pop Chevy's Avatar
2021 C1 of the Year Finalist - Modified
Heat is o-k just let it cool slowly. Gimme a call if you need help.
Old 12-12-2018, 03:54 PM
bj1k
bj1k's Avatar
Thanks for the offer Gregg. I took it up to Butler yesterday to retired corvette specialist ( Bill Beighey , maybe you know him ) to see if he can do anything with them . Waiting to hear back .
Old 12-12-2018, 04:35 PM
GEM '62
GEM '62's Avatar
Years ago when I rebuilt my front end, the bushing would fall through, so I guess someone had reamed them, in the past. I ended up making my own bushings. I don't recall how tight, or loose, I fitted them, but they are still good after 100K miles.
Old 12-13-2018, 06:30 PM
Roger Walling
Roger Walling's Avatar
Received 1,589 Likes on 661 Posts
Whats a kingpin?
Old 12-13-2018, 07:49 PM
DONR
DONR's Avatar
Default King Pins
I guess you took out the safety pin out before trying to knock the pin out. I took a customers king pins out in A 60 today. After taking the safety pin out and the top and bottom clips and plugs out the king pins slid right out. I pushed them down.I loosened the backing plate bolts off so the pin would slide by it. Hope this helps.
Don
Old 12-14-2018, 12:49 PM
bj1k
bj1k's Avatar
The shop that I took them to said that they came right out . The problem that I ran into was that there are small plugs below the spring clips that I was not aware of and they were binding. I was wondering why the metal seemed soft when I would hammer on it when the kingpins are hardened . He said that they had to remove the metal plugs first. I guess the older you get you still keep learning . Maybe there is still hope that I will die a smart man .
Old 12-14-2018, 12:56 PM
bj1k
bj1k's Avatar
Originally Posted by Roger Walling
Whats a kingpin?
If I were 30 years old I would have considered that but the way I see it , the new kingpins will out live me . The originals lasted 60 years . Although I did go with disc brakes and power steering for handling .
Old 12-14-2018, 12:59 PM
DZAUTO
DZAUTO's Avatar
Received 3,766 Likes on 1,669 Posts
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
WOW!!!!!!!!!!!!!!!!!!!!!!!!!!
I don't think any of us considered this as a problem in removing the kingpins, BECAUSE we THOUGHT that we understood from your earlier comments that you had removed them (as you mentioned, or, as we UNDERSTOOD, that you had removed them in your original post). Quote " I removed the caps and "C" clips--------------------------------- "
Old 12-14-2018, 01:13 PM
DZAUTO
DZAUTO's Avatar
When you rebuild the spindles with new kingpins and bushings, there will be (or should be) two caps, or more correctly, plugs, per side. One goes in the top and one in the bottom--------------------AFTER the kingpin and bushings are installed.
These plugs are welch plugs, which are convex. They fit in a groove in the ends of the spindle bores.
Here is a plug and snap ring.
Here is a plug installed in one end of the spindle bore.
Once the plug is fully seated, then use a punch, ball peen hammer, etc, and firmly tap the convex side of the plug to expand and secure it in the bore.
Then install the snap ring.
USUALLY, kingpin kits come with enough parts to rebuild 2 sides. Each kit has (OR should have) two caps that are installed ONLY on the top of the upper bore. They frequently do not fit very tight, so don't beat on then to get them for fit tight.
Old 12-14-2018, 01:18 PM
DZAUTO
DZAUTO's Avatar
Bottom line---------------------------GLAD YOU FINALLY GOT THEM OUT!
Old 12-14-2018, 04:06 PM
AZDoug
AZDoug's Avatar
Received 1,477 Likes on 904 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
I always used a center punch to punch through the welch plugs and lever them out. AFTER I removed the center pin retaining bolt.
Doug
Old 12-14-2018, 05:20 PM
bj1k
bj1k's Avatar
Tom , When I referred to removing the caps I meant the dust caps shown in your bottom photo . Since I never attempted to replace these type of kingpins before and there is no instructions that come with the kit , I was not aware that there were plugs on top of the king pins . What is surprising is that I put them in my 20 ton press and they didn't move . If I would have known that they were there , it would have been easy to remove them before trying to press out the kingpins .
Old 12-14-2018, 05:24 PM
  #33
AZDoug
AZDoug's Avatar
The drawings in the ST-12 come in handy at times, as well as looking at the parts in the rebuild kit first and saying to your self: I wonder what these flat discs are for?...
Doug
Old 12-14-2018, 05:26 PM
  #34
Dan Hampton
Dan Hampton's Avatar
Received 1,717 Likes on 803 Posts
2018 C1 of Year Finalist
I thought of doing that but scared to mushroom the end making it tighter . I'm thinking about taking it in the morning to a local truck garage that changes a lot of kingpins to see if they can get them out .
Don't use them on the Kingpins, directly. Use the hammer on the outside of the sleeve and move the hammer around the sleeve. Beforehand, try and use some penetrating oil by removing the zerks and see what happens.
Old 12-14-2018, 05:39 PM
  #35
DZAUTO
DZAUTO's Avatar
You cannot re-use the plugs, so it is OK to destroy them.I use a very sharp pointed punch, and punch a hole into the plug, then just pry it out.
Old 12-14-2018, 06:42 PM
  #36
Drothgeb
Drothgeb's Avatar
It usually pays off to check YouTube for a “how to” video before you do anything anymore. Even with things I’ve been doing for years, I’ll check YouTube and find a better way, or how to save some time or a few bucks. Great resource!
Old 12-14-2018, 11:26 PM
  #37
bj1k
bj1k's Avatar
Doug
I do have the ST-12 on order but that didn't do me much good a few days ago and I did wonder what the discs were for but just thought that they might of been used for another year . Who knows without some type of guidance with something that you never did before .
Old 12-14-2018, 11:52 PM
  #38
AZDoug
AZDoug's Avatar
That's how we learn.
Next time you, or someone else is doing a kingpin job, you can say: I know how to do that!
I have whole catalog of things that didn't go exactly as envisioned, the first time I did them.
Doug
Quick Reply: Stuck Kingpins
