[C2] 63 wipers 1 speed or 2?
Here's a description of how the wiper switch functions:
Any time the Accessories circuit is powered, the wiper motor has access to +12 volts. The wiper switch controls access to the ground needed to complete the circuit and operate the motor. The switch housing appears to be grounded by design to the instrument panel, which is grounded to the rest of the car. When the wiper switch is rotated to the Low position, it connects an internal piece with its housing to ground terminal #1 on the motor. When the switch is rotated further to the High position, it also grounds motor terminal #3. When the washer button on the switch is depressed while the switch is in Low or High, it provides a ground to complete the circuit that powers the washer pump.
Armed with this info and a multimeter, you should be able to check the operation of the switch in each position. Using a jumper wire from a known, good ground you can also see if the wiring/motor is operating properly when each wire to the switch is grounded. .... If it appears the motor runs in low and parks when turned off, I'd start by checking the switch and wire that feeds the #3 terminal.
Bangkok Dean (12-11-2018)
Nice that it's listed as an electrical "non-returnable" part too..
Received 1,856 Likes
Here's a schematic showing grounding combinations:
BillC2 (01-23-2023)
And the CC pic of the part number cited shows three electrical spade lugs too - to wit, it should support two speeds (and off/park of course)... The part is defective or badly designed...
