How often do you change oil if car is driven 1k per year?
Received 1,843 Likes
In the meantime, an arbitrary schedule is nothing more than just guessing.
Me? I change about every 5000 miles on these old engines and I'm just guessing because I've never claimed to be too smart. But, I can also tell you, I've never had any engine failures due to my somewhat lax change schedule.
Lot's of commercial businesses use oil analysis evaluations to set their oil change schedule and they make their living out of equipment that has to run reliably and long term to avoid downtime due to overhaul or other repair.
If I drove 1000 miles in two days would I change the oil? Nope!
If I drove 5000 miles in one week would I change oil? Nope?
If I drove 10,000 miles in two weeks would I change oil! Probably but if I made a habit of it, I get an oil analysis and see how the oil was holding up!. And quit guessing1
Received 1,919 Likes
At the rate my current engine leaks, I don't think an oil change is needed at all, just swap the filter every several thousand miles.
But seriously, oil changes are so cheap and easy, it doesn't matter if economics is your goal.
But I like the idea of an annual oil analysis, then drain and refill when the analysis says it's shot.
Annually at a minimum.
Former Vendor
St. Jude Donor '12
Camaro Corvette Truck Tuner in Tampa
My fun cars only get about 1500 miles a year on them. In those 1500 miles, there's some good spirited driving. I usually change the oil once a year. This gives me a little time under the car making sure its all good.
Received 1,974 Likes
Duke
2 years if it makes you feel better. I would do an oil analysis. They have these things on the older cars called dip sticks, if it's still clean I'm still running it. That is my analysis.
For me it's every two years or 5000 which ever comes sooner in both the C! and C5. In 65 years of driving i have never had an oil related failure (in a street driven car)..
It's also about the oil formulations you're using in the engine. Why not have an oil analysis done to set a base line to schedule future oil changes? I didn't think I would have to say to do it just once. Not every time.
Last edited by lurch59; 12-12-2018 at 05:42 PM. Reason: added words to sentence so it made sense
Oil analysis companies tell us this isn't an accurate way to determine suitability of oil. Viscosity is probably the most important parameter, and color of oil doesn't reveal anything about viscosity.
Received 4,708 Likes
Annually would be fine even for a conservative person, If you are so inclined, Blackstone Laboratories will do an oil analysis for less than $30. bucks, check them out online
THIS IS RECOMMEND FOR NEW ENGINES. FOR NEW CARS OR NEW CRATE ENGINES.
"How long can you go between oil changes?"
"The quick-lube chains usually recommend it be done every three months or 3,000 miles, but many mechanics would tell you that such frequent changes are overkill.
Indeed, most car owner's manuals recommend changing out the oil less frequently, usually after 5,000 or 7,500 miles. "
#33
My other car a 1997 Porsche 993 has 41K miles. I drive it maybe 200 miles per year. The last oil change was three years ago. Sometimes I get a guilty feeling about not changing the oil but then I say a few more months. I do not really know when I am going to change it.
I am registered on the Porsche forum Rennlist and through postings I made friends with a retired engineer who was one of the creators of Mobil1 synthetic. He told me that they had during testing two cars with Mobil 1 that went 100,000 miles without oil change. Analysis of the 100,000 mile oil showed not deterioration, It was still good. When they released Mobil1 they recommended the oil to be changed every 25,000 miles but dealers did not go for it. Instead they recommended every 12,000 miles for Mobil1.
I am using Amzoil 10W-40 Synthetic (High Zinc formula) in the Corvette, and Mobil 1 15W-50 in the Porsche.
Cam33 (12-21-2023)
#34
Received 2,130 Likes
2015 C2 of the Year Finalist
I used to change oil every October, as my collection grew from 3 to 5 to 8 it became a hassle and I noticed on some cars I was draining what looked like fresh oil. So I go by appearance, smell and feel. If it is clean, smells good and feels good I leave it alone for up to 2 years and I'm heated & humidity stabilized.
Dan
Dan
#37
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
This issue has been rattling around in my head over the past 2 days.
It's certainly true that "looking" at the oil can't determine if the viscosity has broken down...
But think about it: What would cause a breakdown in viscosity??
- Lots of miles (not a factor for this discussion)
- Contaminants like water, fuel, combustion byproducts (these ARE visible)
- Excessive heat (perhaps a risk - although modern oils, especially synthetic, can take a lot without breaking down)
I guess what I'm saying is looking at the oil may be a pretty good indicator for this specific case (very low annual miles).
#39
You've certainly identified some causes of changes in viscosity, but there are others. Cheap oil has cheap viscosity index improvers which fracture easily and change the viscosity. We also want adequate TBN numbers which protect against acidic oil during storage. I think it is worth it to take the random occasional sample to see how your oil is fairing under your particular conditions, and get an idea how long you can go between changes.
#40
Received 3,443 Likes
Very subjective question. IF the car has a properly functioning PCV system, is tight with little blowby, has a properly calibrated carb that does not provide an excessively rich mixture either during cold start, warm up, and fully warm, and IF when driven the engine reaches operating temperature for at least 30 minutes and it is stored inside in a non-condensing humidity environment, then every two years at 1K miles per year is perfectly acceptable.
Engines with road draft tubes should probably change the oil more frequently because the old road draft tubes offer poor ventilation and more rapid buildup of blowby contaminants in the crankcase.
If the car is stored during the year and a change is due prior to the end of storage, the oil should be changed before the car goes into storage. The clock doesn't run on fresh oil in the crankcase as long as the car is stored inside in a non-condensing humidity environment.
Duke
Duke
