Ordered a 4 post lift today
I finally called Bendpak today after measuring and marking off where this will sit in my garage. I was hoping to miss any 2019 price increases.... I had the height so I went for the taller lift. I was surprised when they asked if I wanted it in 110 or 220 configuration, as there is zero mention of this anywhere on the Bendpak site. So i opted for the 110v. I added 2 jack lift systems, and the caster kit, so in 2-3 weeks it will be delivered to my friends shop, where he can load it on to my car hauler, & let's hope my little New Holland tractor can drag the crate off the trailer & into the garage.
Received 1,126 Likes
I installed a Bendpak lift like this for a friend and I was very impressed with the quality and construction. He has had it over 4 years now with zero issues.
Joe
Joe
Bendpak is a much nicer lift than I own. You will wonder why you never got one sooner. I have them because they offer such cheap square footage for the money. One is extra tall and long. That adds a lot of versatility. I also had 3 of them on a car trailer. It is easier to break the package on the trailer and use the front end loader. I also have a NH Boomer and it does a great job. Mine could not lift the entire package. I did one before and it was easy to slide off the end of the trailer. Then lift the remaining end up in the air and pull the trailer out from under it. Wished I lived closer I would help you put it together.
I wouldn't worry about lifting the entire crate, just disassemble the crate and lift the pieces individually. I believe the heaviest pieces are the ramps and 2-3 guys should be able to lift them. Or at least drag them with a dolly. The 220 would have made the hydraulics work faster, but it's definitely not necessary. If you do find it too slow, you can probably have the motor rewired for 220.
Good luck, and you're gonna love it.
GUSTO
GUSTO
If possible use an engine hoist and two furniture dollies from harbor freight along with four 2by4’s to span the dollies. You can easily roll it around including off your car hauler.
You will love the hoist and a yellow strap to move the two king runners into position. The heaviest part of the whole thing by far.
I built two atlas lifts this year this way including mine no issues. If I can help make the process clear PM me we can talk on the phone.
2015 C2 of Year Finalist
I have the HD-9, 220V, like it quite a bit. The power unit failed in the first few months, their local installer did an outstanding job of getting it swapped out under warranty and up and running again quickly.
220V units are substantially faster than 110V, which I deemed very useful. But I already had 220 in my home garage so it didn't entail any extra effort or cost.
2021 C1 of the Year Finalist - Modified
I bought a Bendpak and love it ! My advice- back the trailer in the garage and take the crate apart in pieces. The crate is VERY heavy. However after taking it apart then I was able to assemble the lift myself.
Congrats on the lift. I bought my Bend Pac about 10 years ago and wonder why I did not install it much sooner. Think about putting in a 220 volt outlet for the lift. If you have a service panel in the garage, adding 220 is very easy. If I remember correctly, the motor can be converted to 220 easily as well. If its not too late, get the aluminum ramps. Your back will thank you and you will eliminate the chance of walking into ramps when the lift is in the up position. Right now, my ram is out of the lift for new seals. The main seal started leaking fluid. Should be back in later this week. Enjoy. Jerry
Received 4,553 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Thanks for all the positive replies. I read quite a few old posts on this subject, and the Bendpac seemed like the one to get. I talked to them about the 110 vs 220, and yes, it can be converted at any time, but I wont be using this like a shop would, so whether it's a 40 second lift time or 80 second lift time, it wont bother me a bit. Thanks for the tips on assembly, leaving the pieces on the trailer until needed does seem to be a good idea. My tractor is pretty good size, diesel 4x4, with a bucket that has put many fully dressed big blocks in and out of the various boats I've had over the years, so I should be able to get these pieces maneuvered into position with it just fine. I can always stick the brush hog on back for some extra counterweight if needed.
Received 2,130 Likes
2015 C2 of the Year Finalist
Bendpack HD9W 220V
I agree.
The left hand unit had a minor shaft seal leak at the cylinder and they swapped it out. Its been 3 years and so far so good. As long as you place close attention during all movements these are fine units. The minute you are not paying attention is when a lock hangs and the car comes down crooked and a **** storm is pending. I love these lifts but consider them as safe as a chain saw.
Dan
hcallaway (01-03-2019)
I was thinking that I could use the tractor to set the heavy stuff on to my car dollies for maneuvering, & from there, my neighbor & his 3 boys (all strong 20 somethings) & myself can hopefully handle it from there. I have used fence posts before to roll a few hot tubs on and off the deck, those are never fun to move either. I learned that it's worth it just to pay for the install on hot tubs.
