1966 SB - Trying to Locate a 2 1/2" High Air Filter Element -
Received 1,308 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
I thought this issue was behind me, but it has again come about. (I posted about this a while ago)
I'm trying to locate an air filter element for my '66. I jumped through hoops finally getting one that will fit. By fit, I mean not hit the hood. Not too much to ask, right?
I put in a Purolator A60074 that measured 2 1/2" high. The Fram equivalent was too high at 3". So, with part # in hand, I order another A60074 only to find that it is 3" high. I've tried several Google sites with cross reference charts and can't come up with one.
Has someone here dealt with this and found an answer? Thank you.
Are you needing one exactly 2 1/2" tall, or are you looking for one that doesn't exceed 2 1/2"? I bought a Wix 42070 that measures exactly 2" tall, and 12.75" wide.
Not sure if this helps!
cor66vette (01-02-2019)
Thank you. I need one that doesn't exceed 2 1/2". ^ ^ ^
I just checked that WIX # and according to Amazon, the height is 3". I'm not saying yours isn't as you say. This just adds to the weirdness of this. You have a filter that measures 2" but the specs for the filter indicate 3". Nothing about this is more queer than having an air filter in a car that fits, and with part# in my hand, the air filter with the same part# is not the same.
Received 2,330 Likes
You might try a dimension search at the K&N site, and then find a cross reference.
https://www.knfilters.com/search/univ2.aspx?id=s0001
Part Number:42070
UPC Number:765809420700
Style:Air Filter
Service:Air
Type:Media:Cellulose
Height:2.12(54)*
Outer Diameter:12.802(325)*
Inside Diameter:11.035(280)*
Ends:Plastic
CFM:120
I agree that it is weird as well. I don't trust Amazon for actual specifications. This is the specs from the Wix website that I copied and pasted for you. I also measured mine, and it is what it says it is. The best part is that I found this filter at my local AutoZone, O'Reilly's, and NAPA.
Style:Air Filter
Service:Air
Height:2.12(54)*
Ends:Plastic
CFM:120
Received 3,043 Likes
St. Jude Donor '05
Try Summit or Jegs?
cor66vette (01-15-2019)
I brought the filter with me to the auto parts store and compared it to what was on their shelves, and ended up with Purolator A-60102 ... in case anyone is interested. Thank you all.
