[C2] Electrical Ignition Experts
#62
If that replacement coil is a reproduction part you will be in for more troubles, go get a NAPA Ecklin 12 volt replacement coil and your good to go.
If it's a NOS 202 coil you will be fine, the old coil looks like the oil is long gone and it got hot. I have a 091 coil that looks like that and it does not make sparks correctly.
#63
#64
Received 6,929 Likes
2015 C2 of Year Finalist
Did you old coil have a burnt electrical smell to it
#65
Had the same problem with my Breakerless SE all of a sudden. The positive post of the coil was barely grounding out on the top shield cover. I insulated the the + post with a rubber vacuum plug and that solved the problem instantly.
#67
Had a 78 Monza that started when it wanted too. Factory HEI ignition. Found that if I bumped the top of the distributor with my fist while jumping out the starter solenoid with a screw driver it would start right up. Turns out the bushings in the distributor were too worn. New bushings and never had a problem again. I would think the same is possible with a magnetic pick up conversion.
#68
Received 1,308 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
In a way I envy your scenario, Leif. Yours will either start or not start, and you're still in your garage where you can trouble shoot while the problem exists, whereas mine starts, then might or might not crap out while driving and leave me stranded somewhere.
#69
Make sure the coil + and - connections are perpendicular to the center line of the car. If not, they can make contact with the shielding. First time I drove it from the house. Didn't get 200 feet. Took the shielding off and it stated right up. Noticed it right away and thought "OOPS!"
#70
#71
Today's update. The new coil has not resolved the issue. Issue continues as before. Car will crank but won't start. Then, after leaving it alone it will start on the first crank. Car runs and drives flawlessly after it starts. Twice this past week, after going for an hours drive, when I pulled back into the garage I would shut the car off. The first day it would start up immediately after shut off...several times. The second day after a beautiful drive, pull into garage, shut off the car and attempt to restart...cranks but not start.
Now today, went to the garage to go for and drive a she wouldn't start. I removed the plug wire from #1 and inserted an inline spark tester. The wife was home so I had her come out and crank the car so I could observe the tester...no surprise, no spark. Help me narrow this down before I start replacing parts. Again, so that no one needs to re-read this entire post, this car has all new wiring harness(s) five years ago. ALL connections at battery, ballast resister, coil, starter, etc are clean, tight and non-frayed. Coil primary is 1.3 ohm and secondary is 12400 ohms. Battery is fully charged and shows 13.4 volts. Where do I go from here. Obviously, this is driving me nuts!!!
#72
a new set of points is 15 bucks and 20 mins of your time.
SWC Tim (03-10-2019)
#73
I hear you Keith and that may be the route I will pursue next just to eliminate the breakerless ignition. I just can't wrap my mind around the fact that it is only intermittent and when it does start it runs perfectly. I would think if the module were bad it would run poorly and cut out and leave me stranded.
But, again, if the consensus points to the points (no pun intended) then I will do that.
#74
throwing parts at problems is a bad idea but with intermittent electronic problems that will drive you up a wall and make you bang your head trying to figure it out it will help you to keep it basic. and keep you sane
#76
With my Monza, It would also happen while cruizing down the highway.
#78
Lou
leif.anderson93 (03-10-2019)
#80
I'm a big fan of the electronic conversions but throwing some points in there might not be a bad idea...
Here is the troubleshooting page on the Breakerless SE if you want to chase that some more before replacing:
http://www.breakerless.com/techhelp.htm
On my 61 there was a bad terminal lug on the ignition switch that would cause a non-start issue about 1 in 20 times and was the dickens to find. I wound up temporarily putting a blob of solder on the lug so it would make contact with the terminal on the dash harness effectively until I could replace the switch.
I'm also not entirely ready to exonerate the bulkhead connectors....that is not an optimal design and depends on constant pressure at a perfect angle for all those connectors to pass electricity through friction....they cause some bizarre problems at times..
leif.anderson93 (03-11-2019)
