1956 master cylinder ( chromed)
Someone chromed my 56s original brake master cylinder. I'm wondering if anyone has ever removed the chrome on a cast part with success.
You could soak it in a bowl of muriatic acid, but probably not for too long in case it starts eating away the good part.
1925_duane (02-01-2019)
Compare the appearance of your plated master cylinder to one that is completely original. If yours looks smoother than the original housing, it will still be smoother after the plating is gone.
I'd just find another master cylinder.
I am thinking along those same lines. It will never look original. Guess I'll be looking for a correct one that is either good or can be rebuilt.
You will need a 54502233 casting if correctness is an issue.
https://www.ebay.com/itm/1953-56-Cor...Im1:rk:50:pf:0
Will have to be sleeved and rebuilt
Received 6,928 Likes
2015 C2 of Year Finalist
start with Lone Star Caliper and see if they have a rebuilt one
1925_duane (02-02-2019)
Lone Star has a master cylinder. Have a question for some one with a NCRS judging guideline. Was the master cylinder cast gray or painted?
Either natural or semi gloss black. I would paint as you ll have constant maintenance wire brushing the rust off.
The one at lone star is painted black, guess I'll order, and if it is to glossy I'll repaint.
Thanks for the information / help.
Duane
Duane
