'65 396 Barn Find
Old 02-08-2019, 10:09 PM
mattba
CF Senior Member
mattba's Avatar
Nice - the tele/teak wheel and column alone are worth $3K!!
mattba is offline
Old 02-09-2019, 01:29 PM
427vette66
CF Member
No I did not lol.
427vette66 is offline
Old 02-09-2019, 01:30 PM
427vette66
CF Member
Don't think it had tilt or tel but the steering wheel looked like the teak one.
Old 02-09-2019, 01:46 PM
randy ransome
CF Senior Member
Support Corvetteforum!
randy ransome's Avatar
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
No tilt wheel in 65.
randy ransome is offline
Old 02-09-2019, 02:50 PM
Rumblegutz
CF Senior Member
Rumblegutz's Avatar
Appears to have a tele column and a teak wheel. It is very hard to read the engine stamped number but I think it might be a CE block. I think it's a very good find a great price.
You mention "If the rear pumpkin gear ratio code and the m-22 casting number check out correctly". What is the correct M22 casting number?
Rumblegutz is offline
Old 02-10-2019, 12:23 AM
Nowhere Man
CF Senior Member
Nowhere Man's Avatar
2015 C2 of Year Finalist
the same casting number for the M20 and M21
Nowhere Man is offline
Old 02-10-2019, 03:24 AM
centuryoldracer
CF Senior Member
Originally Posted by 65 Pro Vette View Post
Nice find but definitely not a real big block car. Even if it was a Proto type big black car itís still 7000 to early. They didnít start making big blocks till after 11,000 most were between 12,000 and the end of production. Also real big black cars have the battery on the driver side, and do not use a washer bottle they use a washer bag.
In addition I think the BB cars had 80 psi oil gauges
centuryoldracer is offline
The Following User Says Thank You to centuryoldracer For This Useful Post:
Harps (02-10-2019)
Old 02-10-2019, 07:37 PM
randy ransome
CF Senior Member
2015 C4 of Year
I think only if it's a high horsepower car 390,400 HP 60 pound gauge.
Old 02-10-2019, 09:34 PM
BADBIRDCAGE
CF Senior Member
So when finished it will be a beautiful $85,000.00 car with only $115,000.00 invested into it.
BADBIRDCAGE is offline
Old 02-10-2019, 09:56 PM
Railroadman
CF Senior Member
Railroadman's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-Ď19
So get out the sledge hammer and cutting torch, and scrap it for parts?
Railroadman is offline
Old 02-10-2019, 11:06 PM
BADBIRDCAGE
CF Senior Member
Didnít say that. Just be aware of investment to make it whole. If itís your desire to have a big block midyear go for it. Having been there I have a realistic view.
Old 02-12-2019, 01:54 AM
Rumblegutz
CF Senior Member
Rumblegutz's Avatar
You may have missed what I was asking. I asked what a '65 M22 casting number would be.
Yes, '65 option M20 which encompasses the wide and close ratio Muncie known as M20 and M21 both had a 3851325 casting number main case. Only differing in the gear sets and the parts number tag under a side cover bolt they were built with. The '65 option list only listed the 4 speed trans as M20. Chevy determined which trans a car was built with based on the horse power and differential gear ratio. The '66 option list broke out the M21 from the M20 on the option list. In each case Chevy stated which transmission was available with which engine.
That aside the '65s built with an M22 did not have 3851325 on the main case.
The OP alludes to verifying an M22 casting number. I was hoping to learn something.
Old 02-12-2019, 07:42 AM
  #33
jimgessner
CF Senior Member
jimgessner's Avatar
Nice find. Black pw, hardtop convert, you can be driving it for under 30 invested i bet
jimgessner is offline
Old 02-12-2019, 09:02 PM
  #34
427vette66
CF Member
My research and talk with people at the corvette museum in bowling green when i went was that the M-22 was an asked-only option for '65 and had to be ordered with the 375hp fuelie or the 396. The casting number should be the same for the m21 but some had the casting number removed when the particular factory assembled the transmission they didn't want it to be miss represented, some left the casting number. And the only way to tell is the internals and teeth number.
Quick Reply: '65 396 Barn Find
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
