Rebuild or replace motor in my 64 air coupe?
Old 02-10-2019, 05:42 PM
bellyjello
CF Senior Member
The compressor for the A/c.
bellyjello is offline
Old 02-10-2019, 05:50 PM
Frankie the Fink
CF Senior Member
Support Corvetteforum!
Frankie the Fink's Avatar
As MikeM said, have it looked at and you could get off easy - anything from a motor mount to a blown out harmonic balancer and anything in between.... If your engine is running 70lb oil pressure, dollars to doughnuts, somebody has been into it before now...
Frankie the Fink is offline
Old 02-10-2019, 05:55 PM
Easy Rhino
CF Senior Member
Easy Rhino's Avatar
I'm sure you know this, but if your AC system is charged with freon (R12), most folks prefer to just remove AC components from their brackets and set them aside with the hoses still attahed, but without discharging the system.
Easy Rhino is offline
Nowhere Man
CF Senior Member
Nowhere Man's Avatar
2015 C2 of Year Finalist
if your AC is working I would not remove it. you should be able to tie it off to the inner fender
Nowhere Man is offline
Old 02-10-2019, 05:57 PM
emdoller
CF Senior Member
Totally agree!
emdoller is offline
Old 02-10-2019, 08:54 PM
BLUE1972
CF Senior Member
BLUE1972's Avatar
I would not open the A/C if it's working.
I would pull the plugs, pull the valve covers and turn the engine over by hand - check for anything that feels out of place..
BLUE1972 is offline
Old 02-10-2019, 11:30 PM
C2 Hot Cam Guy
CF Senior Member
I second that
C2 Hot Cam Guy is offline
Old 02-11-2019, 10:34 PM
jv04
CF Senior Member
jv04's Avatar
I agree with the comments to see what is wrong with the engine first. If it is not major, fix it.
If it is major, and the engine needs a rebuild, you can come out a bit cheaper, and certainly easier with a basic crate motor (not a high dollar hot rod motor).
A basic crate motor, with about the same HP as your current engine, and a warranty, is a quick and easy fix.
And you set the original motor in the corner, ready for the time when the car gets a restoration.
Good luck with whatever you choose, and you already know to hang onto the original engine.
jv04 is online now
Quick Reply: Rebuild or replace motor in my 64 air coupe?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
