66 427ci. 425 hp lifter noise on cold start.
Old 02-10-2019, 12:57 PM
Rubc555
CF Senior Member
Yes it’s the original block heads
Rubc555 is offline
Old 02-10-2019, 01:15 PM
dmaxx3500
CF Senior Member
dmaxx3500's Avatar
then you better ask the eng builder,or tear it apart to make sure its the right rear cam bearing/cam setup
dmaxx3500 is offline
The Following User Says Thank You to dmaxx3500 For This Useful Post:
Rubc555 (02-10-2019)
Old 02-10-2019, 01:42 PM
TCracingCA
CF Senior Member
I do a round or two of Rislone as I am also cutting open my oil filters to see if nothing bad is happening, and if that doesnít solve it or I am finding metal, I yank it and tear it down!
TCracingCA is offline
The Following User Says Thank You to TCracingCA For This Useful Post:
Old 02-10-2019, 01:57 PM
Rubc555
CF Senior Member
Well I think I will pull the valve covers and check things out when it’s cold .
Disconnect the coil turnover check the valve lash & rockers see where I’m sitting.
most of my noise seems to be Isolated to the right passenger side.
Rubc555 is offline
Old 02-10-2019, 02:00 PM
Rubc555
CF Senior Member
Rubc555 is offline
Old 02-10-2019, 02:26 PM
Rubc555
CF Senior Member
Hey Jack I have the stock valve covers but changed to a custom set had to have some bling and they gave me clearance with the rocker locks
so Iím going to check just for the sake of it 👍
Rubc555 is offline
Old 02-10-2019, 02:34 PM
Nowhere Man
CF Senior Member
Nowhere Man's Avatar
2015 C2 of Year Finalist
With out the grove in the rear cam one side of the engine will get more oil then the other after a while but not enough to keep the rockers lubed.
Nowhere Man is offline
The Following User Says Thank You to Nowhere Man For This Useful Post:
Old 02-10-2019, 03:11 PM
centuryoldracer
CF Senior Member
Another thing to note is one side of the top end is dependent on the distributor sealing in the block just above the gear.
Oil passes through that cavity around the distributior to get to the lifter galley, but only on one side, the other side has a direct oil passage.
centuryoldracer is offline
Old 02-10-2019, 03:15 PM
Frankie the Fink
CF Senior Member
Support Corvetteforum!
Frankie the Fink's Avatar
Originally Posted by Rubc555 View Post
Dang - all my trophies are significantly shorter than I am, how did you get it home?
Frankie the Fink is offline
Old 02-10-2019, 03:16 PM
centuryoldracer
CF Senior Member
Well I think I will pull the valve covers and check things out when itís cold .
Disconnect the coil turnover check the valve lash & rockers see where Iím sitting.
With the valve cover off you could check to see if it is oiling on that side. If either the cam or the bearing is notched it should be fine. Also the distributor fitting snugly down low to seal the oil galley to that side is important. MSD distributors have two small o rings to positively seal that area.
Old 02-14-2019, 08:31 PM
JohnZ
CF Senior Member
Here's the story on the early big-block rear cam journal and bearing - have dealt with this MANY times where people used the wrong cam and/or rear cam bearing.
File Type: pdf
JohnZ is offline
Quick Reply: 66 427ci. 425 hp lifter noise on cold start.
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
