Center console paint 1966
Old 02-10-2019, 10:00 AM
cor66vette
CF Senior Member
cor66vette's Avatar
Default Center console paint 1966
Is there a particular SEM brand paint good for this? I've used SEM on other applications and I like the quality and results. Another paint better? Thank you.
cor66vette is offline
Old 02-10-2019, 10:07 AM
Frankie the Fink
CF Senior Member
Support Corvetteforum!
Frankie the Fink's Avatar
I'll just say that I use the Corvette America interior sprays and have been well satisfied. The color is dead nuts on and they lay down nicely in two light coats....it doesn't fill in the grain and is as durable as it gets...
Frankie the Fink is offline
The Following User Says Thank You to Frankie the Fink For This Useful Post:
cor66vette (02-14-2019)
Old 02-10-2019, 10:10 AM
Nowhere Man
CF Senior Member
Nowhere Man's Avatar
2015 C2 of Year Finalist
for any color beside black I would use the CA brand dye. for Black I would use Kylon 1613 industrial lacquer
Nowhere Man is offline
The Following User Says Thank You to Nowhere Man For This Useful Post:
Old 02-10-2019, 10:16 AM
cor66vette
CF Senior Member
cor66vette's Avatar
What finish is the black? Semi-gloss, yes?
Old 02-10-2019, 10:22 AM
Nowhere Man
CF Senior Member
semi gloss
Old 02-10-2019, 10:23 AM
Tigershark3
CF Senior Member
Tigershark3's Avatar
Good choice but be careful with the lacquer it'll lift any enamel that's on there now. Best to strip it to bare metal before you paint to be sure. $.02 deposited.
Tigershark3 is offline
The Following User Says Thank You to Tigershark3 For This Useful Post:
Old 02-10-2019, 02:39 PM
cor66vette
CF Senior Member
cor66vette's Avatar
I cannot locate Kylon 1613 industrial lacquer on the Krylon website, or anywhere for that matter. Might there be a revised part number or equivalent?
Old 02-10-2019, 03:02 PM
Nowhere Man
CF Senior Member
Old 02-10-2019, 03:06 PM
Frankie the Fink
CF Senior Member
These folks have it in semi-flat:
https://www.globalindustrial.com/p/j...emi-flat-black
I don't recall a 1613 semi-gloss, but I've never looked for it.
Old 02-10-2019, 07:43 PM
cor66vette
CF Senior Member
cor66vette's Avatar
I see semi-flat, and satin- not semi GLOSS. Is it just me?
I'm pretty sure semi flat and satin are not the same as semi gloss, right?
Or are they?
BTW- Thank you for your input
Nowhere Man
CF Senior Member
what ever the 1613 is really called its what you want as fair as sheen
cor66vette (02-11-2019)
Old 02-14-2019, 08:45 PM
JohnZ
CF Senior Member
You don't want semi-GLOSS - you want semi-FLAT, which is the only way Krylon black #1613 has ever been formulated until they changed it from lacquer to enamel a few years ago. Now you want INDUSTRIAL 5-BALL Semi-Flat, which is lacquer-based, just like the original we all grew up with. All the industrial supply houses stock it - you won't find it at hardware and the big-box stores - they only carry the non-5-ball ENAMEL version.
JohnZ is offline
The Following User Says Thank You to JohnZ For This Useful Post:
Old 02-14-2019, 09:58 PM
Railroadman
CF Senior Member
Railroadman's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-19
I agree, don't listen to the "semi'gloss" posts. I got exactly what John shows through Travers Tool Co, but other similar vendors have it as well.
Railroadman is offline
The Following 2 Users Say Thank You to Railroadman For This Useful Post:
cor66vette (02-14-2019), vark_wso (02-14-2019)
Old 02-15-2019, 06:47 AM
Frankie the Fink
CF Senior Member
You won't get "exactly" what JohnZ shows in the picture anymore unless you find some really old stock....
The new Krylon spray can "look" is in the link in post #9, so don't be put off if it doesn't look like the older can...its the same stuff.
Old 02-15-2019, 10:10 AM
cor66vette
CF Senior Member
cor66vette's Avatar
"'A rose by any other name..."
Old 02-15-2019, 11:44 AM
93RubyRedCoupe
CF Senior Member
93RubyRedCoupe's Avatar
semi gloss
you don't want semi gloss, you want semi flat
93RubyRedCoupe is offline
Quick Reply: Center console paint 1966
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
