[C1] Poverty caps
Received 1,974 Likes
If you are talking about the "dog dish" hubcaps that were installed in lieu of full wheel covers, they were part of the RPO 276 5.5" wide wheel option. Those wheels would not accept the full wheel covers. AFAIK the option was available without restriction. Most C1s that were ordered with the HD brake and suspension options were likely ordered with 276, too, but having the wide base wheels does not necessarily mean FI or any HD options.
Duke
Duke
Anyone knocking those off?
Received 3,769 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Duke
Duke
MOST LIKELY, IF, repeat, IF the 5.5in wide wheels had had the 4 nubs for retaining full wheel covers, then the early Corvettes would have had full wheel covers.
It seems kind of strange that when Chevrolet went to 14in wheels in 57 (on pass cars), the 14in wheels had the 4 nubs for retaining the 14in full wheel covers, but the 15x5.5in wheels did not have the nubs.
Personally, I prefer the dog dish caps on most cars. I like the image of a more plain, hi-perf car. Of course, I also like the things that go with that image, PLUS some creature comfort features such a air cond, PS PB and nice tunes-----------------------------but in a plain jane image. For example, I'd rather have a plain 2dr post Biscayne (with a 409/4sp/posi/black tires/dog dish caps and air cond) rather than an Impala SS with those features.
I did this with my one owner Cutlass (dog dish caps) and I though the Olds community was going to tar and feather me, so I went back to the Olds sport wheels. Oh well-----------
I more or less cloned my 56 into an "Airbox" car and went with wider wheels without nubs and 56 dogdish caps.
VERY EARLY 53 with moon caps and trim rings.
jerry gollnick (02-10-2019)
2020 Corvette of the Year Finalist (track prepared))
2019 C1 of Year Finalist (track prepared)
And of course there were three versions for Corvettes, '57s (like Tom's), '58s, and '59-'62s. Used ones are available on eBay, though they usually need some restoration. If you get some, be careful when you put them on. They're easy to dent.
I like the '58s best:
St. Jude Donor '17
Option list shows 5.5 inch wide wheels with center caps (dog dish) to be a no cost option. You took the full wheel covers or dog dish caps. An either or choice as I understand it. Shop manual also says one could go up two tire sizes on the wide wheels although they came with standard 6.70 tires.
Also, for all years, both pass cars and Corvettes (of the same year model) used the same dogdish caps. Thus, for example, if a person wanted dogdish caps for a 60 Vette, DO NOT, DO NOT, DO NOT say you are shopping for a Corvette, say that you want them for a 60 full size Chevy, such as a 4dr Biscayne. You might check the 58-64 sections of Chevytalk.
Forget finding any (cheap) 57 dogdish caps. The 57 Chevy people also consider them to be like gold!!!
The blackwall/dogdish look is hot.
That has also been my understanding. RPO276 was exactly that--------------------AN OPTION, and NOT specifically tied to any other option or equipment.
Are they riveted or welded?
Duke
In 1960 I bought a new Corvette with the following options:
RPO 276 wheels, including small hubcaps
RPO 686 metallic brakes (NOT HEAVY DUTY)
RPO 290 white walls
RPO 290 white walls
Duke
BUT, as you mentioned, they were an "off the shelf" item at one time. Back in the day, no one gave a second thought to buying a large quantity of, and hoarding 15x5.5 wheels---------------------DAMN, if we had only known!!!!!!!!!!!!!!!
As far as I know, all 15x5.5 wheels were riveted.
For sure, my 56 is a fake Airbox clone, but I do not, and never have been financially capable of buying a real Airbox car. I personally just like the hi-perf image of dogdish caps and wide wheels, so that is what suits my fancy.
The Corvette I referenced in post #11 above was ordered for stock by one of the most aggressive Corvette dealers in Ma at the time, Walker Motor Sales in Palmer. Besides the equipment I have already noted it also came with:
101 Heater
102 Radio
107 Pk brake alarm
108 Courtesy light
109 Windshield washer
121 Temp cont fan]
262 Sun visors
419 Hard top
440 Black & silver paint
469C 270HP engine
675 Posi rear
685 4 speed
so it was far from a "stripped" go fast model, just about everything except power windows ,power top and powerglide !
101 Heater
102 Radio
107 Pk brake alarm
108 Courtesy light
121 Temp cont fan]
262 Sun visors
419 Hard top
469C 270HP engine
675 Posi rear
685 4 speed
If you are saying a new car buyer had the choice of the full wheel disc or the poverty (also known as dog dish) caps with the wide wheel option RPO 276 that is incorrect.
The Corvette wide wheel did not have the 4 retention bumps on the outer part of the hoop which are what kept the full wheel disc on. Without these bumps the full wheel discs pop off with the first corner, pot hole or simply passing over a curb leaving a parking lot. Simply because wheels flex.
It is thought that Chevy did not have a 5.5 inch hoop in use at the time so Kelsey Hayes used a Ford 5.5 inch hoop with a Chevy spyder (center) that would accommodate rivet attachment to the hoop (rim). Or this combination necessitated rivet attachment. These centers were from a base Chevrolet that came with the 3 center bumps to retain the base equipment hub cap. They were named hub caps because they covered the hub and not the whole face of the wheel. The common wide spread use of the name hub cap in reference to a full wheel disc is technically a misnomer stemming from those unacquainted with accurate nomenclature. But language is a living thing and such thinks are susceptible to evolution. Some of it from mis-use. If one looks back to the very early days of the automobile one can see where the term hub cap came from and that that's all they did in the beginning.
