[C1] Z bar Question on a 57
CF Senior Member
Thanked 27 Times
in
Has anyone here ever used a nylon bushing or seat for the clutch pivot ball studs on a c1? I know by design they just ride in a grease cavity, then went to the nylon seats in 63. Will the later C2 bushings work in a C1 z bar? I had mine off today and am noticing wear on the ball on block side. Just looking for any ideas to improve clutch operation. Thanks for any thoughts!
CF Senior Member
Thanked 3,168 Times
in
I don't know of anyone who has tried nylon bushings, but, the engine side ball stud is the easy one to change...I'd swap a new one in and drive on. Some add zerk fittings to the bellcrank tube the ball studs ride in so they can pump it full of grease..
