[C1] Front End Rebuild Aluminum Shims
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Received 1,435 Likes
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
they were not factory in 54 55
they were added in 56 to improve caster and wheel returnability
not correct for judging in case your going that route
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
My '54 doesn't have them, and I don't miss them. Steering is light and almost two-finger-easy. Almost.
If you install the shims, steering effort will increase somewhat. That's the down side of adding caster. On the plus side, your steering will have a more pronounced tendency to return to center after turning.
If you are satisfied now, without shims, with how the steering returns to center after a turn, you won't notice any benefit by adding them.
Jim
Jim
I used 2 per side on my 61, works very well. But I have power steering. Without power, I’d probably start with 1 per side.
If you don’t like it with the shims, it’s pretty easy to remove them.
