64 Drivers side vent window
Old 02-14-2019, 10:34 AM
Redbird
Support Corvetteforum!
Redbird's Avatar
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
Default 64 Drivers side vent window
Here is a picture of my drivers side vent window that is not aligned correctly. Also, a picture of the door with panel removed. Where do yo start to correct the problem?
Old 02-14-2019, 10:59 PM
Valp
Valp's Avatar
I have the same problem. I'll be watching this closely!
Old 02-15-2019, 12:46 PM
DZVette
DZVette's Avatar
Redbird,
You can gain access to to see what the t-post attachment to the regulator looks like by removing the access plate below the vent window. It might be that something is amiss with the t-post insertion into the regulator. I can't see what shape your hinge pivot is in so we don't know if something is amiss there.
The pics below (also attached as a pdf file) should get you going on taking a look at the bottom end of the vent window and its mating with the regulator.
Hope this helps a bit.
Dave Z
Old 02-16-2019, 03:32 AM
alexandervdr
alexandervdr's Avatar
to the OP, in the first picture your hand is covering the pivot. Same picture with a view on the pivot could help.
Is it correct that the bottom of the window is aligned fine (right bottom of the glass against the stainless frame)?
Old 02-16-2019, 09:06 PM
Redbird
Redbird's Avatar
I just replaced both regulators. I will look at the pivot tomorrow.
To 64 Drivers side vent window
Quick Reply: 64 Drivers side vent window
