[C1] Adding dual master cylinder
Hi C1 guys,
What's the best way to add a dual master cylinder to a 1959?
I have a friend who owns a '59 who had a recent scary experience where the brake line to the rear wheels rotted out (pinholed) so he lost all braking due to the fact his car has the original single circuit master cylinder. He escaped disaster by using his parking brake and gearing down.
Is there a retrofit kit available? Which M/C is best to use?
Thanks,
-Alex
Thanks,
-Alex
There are several, most come only with front disk upgrade. This is not a recommendation, just an example:
https://www.ebay.com/itm/1953-62-CHE...-/171192519246
For a "do it yourself" solution, search the C1 forum for "MOPAR".
I did the dual master cylinder set up with the mopar unit. Someone on this site has a very good thread & instructions on how to do it. You need a few skills & tools, but it works very well.
I think the master cylinder I used was from a roadrunner. I also added disc brakes at the same time
2020 C1 of the Year Finalist - Unmodified
Corvette of the Year Finalist 2018
2017 C1 of Year Finalist
2015 C1 of Year Finalist
Corvette Central has nice Dual MC/Disc conversion kit: https://www.corvettecentral.com/c1-5...59%26count%3d9
Don't believe he is looking for disk brakes.
You can add a dual master cylinder using the extension tube kit available at multiple Corvette parts suppliers. Works good, looks OK, but obviously aftermarket.
If you can do a little bit of fab work, the late 60s early 70s Mopar master cylinders can be modified to attach directly to the firewall. Works the same as with the extension tube,but looks better. Search on Mopar master cylinder to find the threads on it. Mine looked like this after the installation, took about a day to do it.
The following 4 users liked this post by Drothgeb:
58neverending (09-29-2020),
59BlueSilver (02-18-2019),
Loren Smith (02-15-2019),
Mr Fufu (02-15-2019)
Pro Mechanic
Received 1,303 Likes
2023 C1 of the Year Finalist - Modified
Don't know if the company is still in business; ABS Power Brake. They had a dual replacement master cylinder that looks like an original 50s master (part #81103). I'd buy one but I can't find them anymore.
ABS is still in business (at least their website is still active)
http://abspowerbrake.com/
Here is a picture of the MOPAR dual MC on my '59.
Charles
Charles
The following 3 users liked this post by cbernhardt:
Tether Man
Received 2,019 Likes
2019 C1 of Year Finalist (appearance mods)
Works very well with my front brake disk add on.
Moose master cylinder
Rather than modifying the mopar master for my 62 I made a 1/4 inch thick adapter plate so you can use the master as it is off the shelf with no modifications.
Mr Fufu (02-19-2019)
Finalist 2022 C1 of the Year - Modified
you wouldn’t happen to have a picture or sketch of that would you? I’ve got a mental picture but there’s no need to re-invent it, even a good description would be nice. Thanks
Thanks guys for the excellent info on fitting a dual master cylinder onto a C1.
I'll relay this info to my buddy who'll be delighted to learn about it.
Maybe he'll join this forum too!
Cheers all,
-Alex
Cheers all,
-Alex
64Corvette (02-20-2019)
The following 3 users liked this post by jerry gollnick:
If someone has an unmolested MOPAR MC would you measure the rectangular mounting flange and post the measurements? It has been several years since I did the modification, but I seem to recall that I was going to try to do the same thing (make an adapter plate) but the MOPAR flange was too wide to fit in the fiberglass cutout.
Charles
Charles
