63 wiring diagram
8th Gear
63 wiring diagram
Anyone have a wiring diagram for a 63 split window they wouldn't mind sharing with me ? Pleas email me @ Mickeymantle.7@hotmail.com Many thx
Received 19,236 Likes
'20-'21-'22-'23-'24
Moved to C1/C2 Corvettes.
I have a 2 page one that you can use. Hope it tells you what you need.
Joeybaga of Donuts (02-18-2019)
Check your turn signal switch adjustment carefully. Might save you a lot of time. And make sure the wires are all plugged in completely at the connector for the switch.
I should do a permanent article on troubleshooting the 63 switches. With a black Sharpee pen or blue tape mark where the cable is adjusted on the switch so you can put it back in the same place then remove the cable. With the key on operate the switch by hand to both extremes - if both sides (and brake lights) work the switch is good. The cable needs adjusting or the mechanism under the horn button is malfunctioning. To adjust the cable put the switch on the column in the left turn signal position and the turn signal handle in the left turn signal position and tighten the cable then test.
Jay
