Avons For My '62
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
Received 1,974 Likes
Treadwear is 80. Like said above, if they last 10-15000 miles, that is years on my car so despite expense, it is worth it. Yes they are sticky. Just rolling around in the garage and driveway, amazing what they pick up lol. My thinking is, to get the great tires in 17 and up inch sizes, I would need new wheels too, so it wasn’t out of line to go for these tires. And I am one of those guys that just prefers the look of 15’s on these cars!
I have had a set of CR6ZZ 205x15 on my 63 coup for 2 years and recently a set of 215x15 on my 67.
Expensive but absolutely fantastic tires. Will do more for your handling and stopping than any other mod.
The 215x15 were a little bit of a tight fit, shaved the inner fender lip to 3/8 inch front and rear, and went with 1 degree neg camber in the rear.
SWC Tim
SWC Tim
Go to the Roger Kraus Racing or Avon Web site, download CR6ZZ spec sheet pdf and carefully review it before you buy.
Duke
A WARNING TO ALL! The 215/70R-15 will likely not fit C2s without shaving the fender lips. The 205/70 and 215/70 15" sizes are within about 0.1-0.2" OD and therefore revs/mile, but the 215/70 has nearly an inch wider tread. Also the revs/mile specs appear to be the "rigid body" calculation based on inflated OD, not the actual measured loaded revs/mile from actual measurements on a tire dynamometer. Multiply their values by 0.97 to get an approximation of actual loaded revs/mile. For reference OE 6.70-15s are 760 and 7.75-15s are 775. Speedometer differences with either size should be marginal.
Duke
Duke
So I felt I was getting a 0.3" wider tread with only a 0.1 increase in the section diameter.
Bob
I wonder how they would do in the rain? No side skipes? Duke used to swear by a particular tire for our old C1 and C2s. i don't remember what it was , name began with a V as i recall.
I vintage raced for 20 years and sticky tires are great on the track but boy they pick up ALL kinds of stuff and get embedded with sand and small rocks. They throw bigger rocks up in the wheel wells. I want to go with a harder compound for the street.
jim lockwood (02-21-2019)
https://www.tirerack.com/tires/tires...Sprint+Classic
They appear to be made in Holland.
GUSTO
jerry gollnick (02-22-2019)
I did not realize they are THAT sticky. Anyone know what the next best speed rated radial tire is that is a little harder? I was planning on replacing my 205/70 x 15s with the Avons but may re-think it as all of my driving is street but often spirited and with curvy mountain roads.
SWC Tim
68hemi (02-21-2019)
Siping, the narrow slits you see in all season tires, are primarily for snow traction. Look at any serious summer high performance tires and these are absent. The CR6ZZ has plenty of water evacuating grooving to be safe to drive in the rain, but be cautious.
Also, DOT legal racing tires and summer high performance tires have a fairly high "glass transition temperature", which is the temperature that the compound suddenly hardens and the tires can become slippery. It's usually in the range of 30-40F degrees. Toyo warns not to drive their Proxes RA1 at less than about 40 degrees as it may cause tread cracking.
The next best alternative to the CR6ZZ is probably the Vredestein Sprint Classic, made in The Netherlands and very popular in Europe on vintage sports cars. It's available in a 215/70R-15 either H or V-rated. I can't remember which. An easy Web search will reveal more info and retailers.
Duke
The following 2 users liked this post by SWCDuke:
jerry gollnick (02-22-2019),
SWC Tim (02-21-2019)
