[C2] 67 L36 vs L68
Old 02-20-2019, 12:37 PM
jwmac87
2nd Gear
jwmac87's Avatar
Default 67 L36 vs L68
Were there any L36's (390HP) that were changed by a dealership to a L68 (400HP)? If so what would be the engine stamp IL or JC ??
Old 02-20-2019, 12:41 PM
Nowhere Man
Nowhere Man's Avatar
Received 6,920 Likes on 4,770 Posts
2015 C2 of Year Finalist
Unless the dealer swapped out the block it would remain the same. No one will know if any dealer did that but it’s a simple swap. Just the intake, carbs, air cleaner, and other small parts.
Old 02-20-2019, 03:39 PM
Geralds57
Support Corvetteforum!
Geralds57's Avatar
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Welcome to the forum!
Old 02-20-2019, 06:14 PM
63 340HP
63 340HP's Avatar
Received 2,330 Likes on 888 Posts
The dealer would not change the stamp on the block, regardless of what intake assembly was installed after they took delivery of the car.
Dealers made many parts swap, for paying customers, but documentation from the dealer is more important to a collector than the physical parts (for example, a Yenko invoice or similar document showing the change).
I would expect an L36 block with a 6-pack would receive flight judging point deductions (if a TF restoration is a goal, otherwise it looks cool and if it works well the 6-pack can deliver good fuel economy).
Old 02-20-2019, 08:49 PM
jwmac87
2nd Gear
jwmac87's Avatar
Just asking because I have seen a window sticker (reproduction?) that showed an L36 in the top part of the RPO's and at the bottom a L68 conversion that listed for about $104.00 extra. I guess the block should still have T----IC stamp on it. ??
Old 02-21-2019, 04:51 AM
Nowhere Man
That is how GM billed the L68.
Old 02-21-2019, 01:13 PM
MelWff
MelWff's Avatar
Received 1,806 Likes on 1,597 Posts
As stated above the window sticker would show both, it is not a conversion, the block would be stamped by the factory JC.
To 67 L36 vs L68
Quick Reply: [C2] 67 L36 vs L68
