[C2] 1966 L72 Restamp?
Old 02-27-2019, 11:30 PM
Greg
Just another Corvette guy
Support Corvetteforum!
Greg's Avatar
Received 3,835 Likes on 1,782 Posts
Default 1966 L72 Restamp?
Found this on another site I frequent. Seller is calling it orig. numbers match but it looks a little sloppy to me.
Your opinions?
Old 02-28-2019, 12:56 AM
tuxnharley
tuxnharley's Avatar
Received 1,937 Likes on 1,183 Posts
Looks like the block was decked. Machining marks run lengthwise instead of outwards. I also see the shadow of old characters. Doesn’t look original to me.
Greg (02-28-2019)
Old 02-28-2019, 01:49 AM
rongold
rongold's Avatar
Location: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Stamping
Those numbers look like they were stamped individually instead of with a gang stamp. The spacing between the digits is all wrong and they're crooked too !!!
RON
Greg (02-28-2019)
Old 02-28-2019, 02:24 AM
Greg
Greg's Avatar
Agreed Ron. That was my first thought when I saw this.
Here is a link to the ad:
https://forums.aaca.org/topic/323088...te-l72-427425/
Pretty grody underneath.
For $90K I'd expect a lot more.
Old 02-28-2019, 05:14 AM
Dan Hampton
Dan Hampton's Avatar
Received 1,720 Likes on 805 Posts
2018 C1 of Year Finalist
Absolutely horrible color.
Old 02-28-2019, 07:07 AM
provette67
provette67's Avatar
This is the same seller that had the "Bloomington Gold guaranteed" restamped small block. I know that this is a consignment shop,but they may want to take a look at what they are selling. Here is another of their cars mentioned here on the forum.
https://www.corvetteforum.com/forums...nal-motor.html
https://www.hemmings.com/classifieds...e/2132883.html
Greg (02-28-2019)
Old 02-28-2019, 08:33 AM
427 Sidepipes
427 Sidepipes's Avatar
Not too bad... especially if you hit yourself in the head several times with a crowbar, rub your eyes really hard, and squint in poor lighting:
Greg (02-28-2019)
Old 02-28-2019, 09:15 AM
66 Double B
66 Double B's Avatar
Stamp date is April 11. The build date by VIN is April 2
Does not jive.
Greg (02-28-2019)
Old 02-28-2019, 10:41 AM
provette67
provette67's Avatar
Does not jive.
No mention of the date on the block. But it states that it is 3904351 casting. Which was used in '67. There are a couple that have been shown used in '66 production. But those cars were in the last week or two of production in July '66
Greg (02-28-2019)
Old 02-28-2019, 10:56 AM
65GGvert
65GGvert's Avatar
Received 3,217 Likes on 2,301 Posts
The real one would use I's instead of ones.
Greg (02-28-2019)
Old 02-28-2019, 12:00 PM
Powershift
Powershift's Avatar
Received 1,681 Likes on 1,307 Posts
Not even close................. But I might use this photo if I give a class on block stamping (restamping) as to what to avoid.
Larry
Greg (02-28-2019)
Old 02-28-2019, 01:27 PM
provette67
provette67's Avatar
Well at least this time the seller does not claim Bloomington certified
Greg (02-28-2019)
Old 03-01-2019, 09:47 AM
woodsdesign
woodsdesign's Avatar
Your opinions?
I know the previous owner of this car. It was a strip out that was bought and put back together sometime in the 80s. I believe the seats and engine were the main components.
So, it is not the original motor.
Old 03-01-2019, 10:09 AM
csherman
csherman's Avatar
Received 1,421 Likes on 734 Posts
C1 of Year Finalist (stock) 2019
no way....
Old 03-01-2019, 11:32 AM
provette67
provette67's Avatar
This seller is 0 for 2 in Corvette ads that have been brought to this forum. Both restamps and bad ones at that. The other car with the "Bloomington Gold documentation regarding the motor" brought the owner of Bloomington Gold and forum member to post that the Motor was not verified by Bloomington. He added this "Documentation is quite good, with the important parts being the documentation from Bloomington Gold regarding the car’s matching-numbers status" Apparently the seller has forgotten to clarify the ad. Not looking good for credibility. Having said that I have inspected a '65 GTO there. The car was every bit as described and then some. So maybe they are just not as versed on these cars.
Old 03-01-2019, 04:56 PM
Greg
Greg's Avatar
Originally Posted by Rumblegutz
What is the digit before the 2 in the vin derivative 611_247 ?
Woodsdesign do you know as you knew a previous owner?
It looks like an "8" to me. But it is stamped much lighter than the numbers next to it.
Old 03-01-2019, 04:59 PM
Rumblegutz
Rumblegutz's Avatar
Greg, thanks.You are right. The vin tag in the link above confirms it.
To 1966 L72 Restamp?
Old 03-02-2019, 06:33 AM
woodsdesign
Remember, this car was rebuilt back in the early 80s when re-stamps were not a big deal. It was done by a professional shop and done right. Mechanically, I am sure the car is fine.
Old 03-02-2019, 08:50 PM
Greg
Greg's Avatar
I agree woodsdesign, that is probably where the car was re-stamped. And if it was done in the 80's, it was probably without the intention of frauding anyone. However I don't think they stamped the original block that the car was born with as this one is a 3904351 cast which wasn't used until 1967. Possible on a very late build '66 maybe, but this car is a March build, which I think is just too early to have the '351 block.
G.
Old 03-02-2019, 08:55 PM
woodsdesign
G.
As I said in an earlier post; I know the history of this car. It is not the original block.
Greg (03-02-2019)
Quick Reply: [C2] 1966 L72 Restamp?
