1965 Powerglide replacement
Greetings,
I am looking for opinions on a replacing a 2 speed auto trans in a 1965 Corvette coupe possibly with a TH350/TH400 or modern overdrive unit.
I understand the transmission tunnel is narrow on C2's and do not want to modify the tunnel for fitment.
Please help, what are my options?
Jen
Jen
Received 2,127 Likes
Have you used the "search" function for this subject? Several posts on this. Dennis
Received 6,943 Likes
2015 C2 of Year Finalist
a 200R4 is a popular choice. Like Dennis said check the archives
350/400 fairly easy swap...overdrive transmission require MORE work.
Here is my 200-4R install in a '66 ===>> Click Here
George
George
I would look hard at the 200R4 option as others have advised.
Same length as the powerglide so no new driveshaft needed.
Smaller case than all other 4 speed automatics
Well spaced gears with overdrive included
lighter tranny but can be built to hold up behind strong engines.
Never talked to anyone that did not love this swap.
The Turbo 350 would be second choice if cost is an issue.
Received 1,283 Likes
I concur, the 2004R is a great option.
Look specifically for the transmission from a Buick Grand National of a Monte Carlo SS, or get one built to those specifications.
As the others have already said. Why go through the expense and work of replacing the transmission and not end up with an overdrive?
Greetings,
Jen
Jen
Hopefully a search of the archives will turn up several prior threads where these three transmissions have been compared. In general, I think there are several characteristics that need to be compared in order to determine which transmission is the best match for your preferences:
1) Is it a bolt-in installation, or does the rear frame mount require modification?
2) Does it require a shortened drive shaft?
3) Does it use a mechanical throttle position sensor or use computer control?
4) Does it have a lock-up torque converter?
5) How well do the gear ratios match your goals?
I won't attempt to provide a complete comparison here, but here are some examples:
* The TH350 and the 700R4 are bolt-in solutions, while the 2004R requires some modification of the frame for the rear mount.
* The TH350, and possibly the 2004R can use the stock driveshaft, while the 700R4 uses a shorter drive shaft
* The TH350 is a very simple installation, but it lacks the overdrive 4th gear. However, first gear in the TH350 is WAY lower than first gear in the Powerglide, so for any given rear axle ratio, you get much better standing-start launch with the TH350 than with a Powerglide. If you pair the TH350 with a 3.36 rear end, the highway rpm might be sufficiently low for your goals.
* The nice thing about the 700R4 and the 2004R is that the overdrive 4th gear lets you run, say, a 3.70 rear axle ratio and still have low highway rpm. And, this combination has a stronger launch than the TH350 combined with a 3.36 rear axle.
* The gear ratios of the 7004R are spaced differently than the gear ratios of the 2004R (especially for the 1-2 shift). Most people think the 2004R gear spacings are preferable to the 700R4 spacings.
I hope the above summary helps you get started with selecting the transmission that's the best match for your goals. Any of these three transmissions will be a big improvement over the Powerglide in terms of how responsive the car feels. Keep in mind that there are several companies that sell specially-built performance versions of each of these transmissions. And, some companies offer complete kits with all the required parts.
