Small block verses big block?
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
With the available stroker kits for both of these engine what is the largest CID possible and what is the highest h.p. possible to run on pump gas (91 octane) with single carb, no modern FI, turbo, supercharger or nitrous that will fit under a small block hood in either a C1 or C2?
Check World Castings. They have at least a 454 SB with 600 HP pump gas. There are bigger SBs but they have tall decks and may not clear a C1 or SB C2 hood. Not sure how well a standard deck BB will fit, but Edelbrock makes a 555 inch and World has a 540 inch, 650+ HP standard deck BB. I'm guessing forget putting a tall deck BB in either place you asked about.
Received 3,443 Likes
A friend just picked up a Skip White 427 sbc that weighs less than the stock 350, puts out 578 HP and 561 TQ on pump gas, and looks like a stocker. Going into his '68 Camaro....impressive.
The following 2 users liked this post by GTOguy:
Brian VH McHale (04-27-2019),
DucatiDon (03-18-2019)
Received 6,521 Likes
C2 of Year Finalist (track prepared) 2019
Received 1,517 Likes
C2 of Year Finalist (appearance mods) 2019
I have a 496 BBC stock type 4bolt main block ARP heads Mike Jones cam pump gas 91. Built by Mike Lewis Lewis racing engines. 726hp. Also just built 383 SBC pro max heads Skip White magic cam pump gas 483 hp 498tq
Coe56 (04-27-2019)
Received 3,043 Likes
St. Jude Donor '05
383 makes similar torque down low but boy does that BB build from there!
Tell us about the BB combo, nice mill! Dig the Jones pulleys, have a set of those and love em.
If ones looking for a true underdrive system to shed weight, bearings that dont bust at rpm thats what you want, not summit stuff.
bouhgt mine from Richard Childress Racing when they still made em
With the available strokes kits for both of these engine what is the largest CID possible and what is the highest h.p. possible to run on pump gas (91 octane) with single carb, no modern FI, turbo, supercharger or nitrous that will fit under a small block hood in either a C1 or C2?
The combination of a 4.125" bore and a 4.000" stroke yields a 427 CID small block. Unless you are willing to spend big $$, this is about as far as you can economically build a small block. To achieve even higher displacements in a small block form factor, aftermarket manufacturers such as Dart and World Products offer blocks with one or both of the following changes:
1) A raised cam that increases rod-to-cam clearance
2) A raised deck that allows a longer stroke
With these changes you can get to 454 CID and beyond, but it gets very expensive. The raised cam requires an aftermarket timing gear set that may end up having to be a belt drive. The raised deck means that factory intake manifolds won't bolt on. If you really want more than 427 CID, I think it would be less expensive to start with the big block form factor.
My sense is that the "sweet spot" for cost effectively maxing out the displacement of the small block form factor is about 427 CID. With a 4.125" bore and 4.000" stroke, all of the standard small block parts such as heads, intakes, timing chain, timing cover, and oil pan will bolt right on to the 427 CID short block.
Coe56 (04-27-2019)
St. Jude Donor '05
If one has a 383 and needs a big gain that 400 block offers the solution.
tpi421vette here has a44x ci sbc that makes over 900 lbs tq with some squeeze, stick car too and street driven
Unless one knew what they were looking at couldnt tell it apart from any other sbc
Limiting factor is head selection on 23 deg stuff
Coe56 (04-27-2019),
jim lockwood (03-15-2019)
Yes, the Dart block 427 was EXPENSIVE. But my friend always 'goes big'. I would have gone with an iron block 383 or 406 for about 9 grand less than he spent!!! ( I tend to 'go cheap'!)
Well, I asked this since there are so many threads about BBs in a C1. To me it seems the best option for a C1 is 427/500 h.p. SB. Unless you are going to do something with the rear end/fenders to get more tire for traction I don't think you can use anymore engine on the street.
For an all-out 427 small block, the Dart SHP block (about $1500) is probably the way to go. However, with some careful attention to rod selection, a used stock 400 block (about $250) will work just as well. In terms of getting the desired clearances, the difference is that the Dart block has solid cast iron in the area where the cylinder bores are notched to clear the rods, while the stock 400 block has a water jacket behind the notches. So, you can grind the Dart block to clear any rod, but the stock 400 block can not be ground as much. This makes rod selection more critical.
For cam clearance, both the stock 400 block and the Dart SHP block are identical. The only difference is that with the large block clearance in the Dart block, for rod selection you can trade off worse block clearance for improved cam clearance. The Callies Ultra XD rod with the canted rod cap is a good example of this tradeoff. However, that same rod is a bad choice for the stock 400 block because you might hit the water jacket by the time you grind enough on the block to clear the Callies rod.
I continue to be tempted to build the stock 400 block I have into a budget 427 for street use. The plan would be to build a "torque monster" with an emphasis on big torque and a power peak around 5500 rpm. What I'm finding with my 383 is that I have few opportunities in street driving for full throttle runs to 6000 rpm, but I have many opportunities to enjoy the torque from 2000 rpm to 5000 rpm. A properly built budget 427 would give me even more torque to play with in the 2000 rpm to 5000 rpm range.
Last edited by GearheadJoe; 03-16-2019 at 02:12 PM. Reason: correct Callies rod to XD
Received 3,768 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Today, there are MANY, MANY options for both cubes and power with either a SB or BB.
For cars that were only built around a SB (early Vettes, 55-7 Chevys, my 51 Chevy, etc), I prefer to stay as economical as possible and use the KISS principle.
My all time favorite SB is a SB400. It is certainly possible to go to 427 with a SB400, but my choice for an all around engine is 420 (bored and .100in stroke) with a set of good flowing heads.
I REALLY prefer to use heads with "plain, no hole" ends. I have not yet bought any, but I see that alum heads with plain ends are now being offered.
This keeps the budget reasonable, provides plenty of power and is TOOOOOOOOOOO EASY to work on-----------if needed.
The other advantage of a SB is the weight.Especially with aluminum heads.
Gearhead Joe summed up the essence of a well done stroker small block: ample torque where the car spends 90% of the time operating, at 1500-5000 RPM. When I buzz my 383 up to 6000 rpm, the '61 stock suspension and chassis gets a bit pushed out of shape. (running stock bias ply tires.....main contributor to this issue). That said, it is just SO pleasant to let out the clutch and ease into the throttle and feel that locomotive torque, virtually all the time. I'm more of a small block fan, especially in these cars. The SBC is a more durable engine than the BBC in my experience as well. Lighter, more durable, same power/torque as a comparable bbc. Win-win.
There is no substitute for cubic inches - I prefer the Real Big Block Engine! There is nothing like it
And for durability, 52 years running strong and never has been rebuilt - They don't build them like they used to!
Not being negative here as I have owned both BB and SBs.
I have a stealth 383 dual quad engine in my 57 that has not been dynoed but my estimate is about 450 h.p. at the flywheel. I would NEVER have considered a BB in this car.
As I stated earlier, I don’t believe you can really USE more than 500 h.p. on the street without bigger tires that require modifications. You can still have 427 CID 500 h.p. In a lighter SB.
Personally I would get more enjoyment out of a stealth big cube SB that would surprise people.
The following 3 users liked this post by 68hemi:
Cubic inches are the same regardless if SB or BB. Tongue is torque regardless. Unless you just like looking at your fat valve covers and having a car with out of balance weight distribution then by all means enjoy your BB.
IMO, there is nothing more awesome looking than a Highly Detailed Tri-Powered BBC
BIG BLOCKS RULE!
And no "Tongue"
