How to secure ignition switch part on 1957
Here is a photo of the chrome part that attaches to the ignition switch that I am unable to secure it to keep it attached. What generally occurs is that this part comes off of the ignition switch when I remove the key. Anyone have any suggestions?
I had mine apart a while ago and don't recall anything special. I think its just a press on, interference fit. Maybe rough up the mating surfaces to make it tighter.
Via (03-17-2019)
Nick, try a little penetrating oil or WD40 around the edge, let it sit for a day, then use some cloth protected water pump pliers to slightly rotate the cap. That should get it started.
Nick Bernier (03-18-2019)
Nick Bernier (03-19-2019)
