[C2] aluminum script valve covers
Received 6,929 Likes
2015 C2 of Year Finalist
just what this board needs anther thread about them but its not about whats right and wrong for the flaw. its about appearance. I got a set of correct non flaw covers for dads 65 L76 but someone steel wooled them in the past and now they are semi shiny. sending them out for re-skinning is out of the question. I could take them to where I work and let them soak in a soapy hot water tank we use to clean aluminum 6061 dip brazed parts that are dipped in a 1100* salt bath. but once you do that you changed it and cant get it back. the other option is to dust them with aluminum paint. or leave them be. NCRS chapter judging is in the future.
Aluma Blast paint looks good to me.
Received 2,330 Likes
Media blasting at low pressure (with walnut shells or baking soda) will remove almost zero material along with surface peening into the depth of light steel wool scratch lines, and restore a near as-cast surface texture. Age and environment under the hood does the rest of the "restoration" of the exposed aluminum surface.
Received 1,044 Likes
C2 of Year Finalist (appearance mods) 2019
Aluma blast looks nice and clean but will never pass NCRS judging. The closest I could come without sending them out was to easy blast with the finest glass you can get and spray a few coats of matte clear it resembles the coating the factory had, still detectable but look correct.
Received 3,043 Likes
St. Jude Donor '05
soda blast it, non abrasive, wont pit. Should look like its supposed to when youre done.
Im not sure on valve covers but on intake manifolds the same works, also if you know someone with a tumbler it will come out looking like the day it was cast.
If yes, what was the coating?
Received 1,856 Likes
Nope. Original covers had no coating - they came out of the die-cast mold at Lester (or Hoover), went in a box, then went on the engine. Once the surface has been "modified" (buffed, polished, or otherwise altered), "re-skinning" will never bring back the original appearance.
The following 2 users liked this post by JohnZ:
63 340HP (03-21-2019),
vetintheblood (03-21-2019)
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
vark_wso (03-23-2019)
Can someone explain to me how is ”re-skinning” done or what it is?
Received 1,843 Likes
To me, a coat of aerosol spray looks better than any re-skinning job I've seen.
Jerry repaired the heater hose fitting on an L76 intake manifold and reskinned it afterwards along with a couple sets of valve covers. I wanted the second set of covers as a spare set. The work was outstanding. Even if his reskinning process doesn't duplicate the original appearance perfectly, it sure looks great to me.
Received 3,766 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
There is a guy here in Okla City that many people use, Fred Hudson. Jerry Bramlett uses him for all the parts of FI units that he restores. I also use Fred sometimes.
These are some damaged valve covers I bought (cheap) for my 56.
I had the damaged fins welded, and the welds ground back down. Then had Fred refinish them.
Do you know how its done?
not trusting him might have been the wrong thing to say. hey may have a great shop and does great work. my luck with specialized shops like his has not been great. and until I know exactly what the process is I don't want it. then when people tell me the process does not make it look original makes me more skeptical of it.
