LED Headlights on a C2 Vette
Received 2,126 Likes
The search function on the forum is not quite that awful... The more restrictive you can make the search by subject, author, regular expression, time and forum section the better the results...
I use it 98% of the time, but then I grew up in IT as the first primitive search engines evolved...
They are the VC4000 5.75" LED Lo-Beam headlight kit - search for "Vintage Car LEDs" and the supplier will pop up in Google....
They are not cheap, but the only real plug-and-play option at the time I bought them...
98% of my driving is with lo beams so that's fine and I've driven with them enough now to know that oncoming drivers have no issue with them.
Frankie,
I know you car is sitting on a lift in the above picture, which would have effect on headlight aim, but based on original headlight beam alignment procedure for Low Beams, I would not want to be meeting your car.
Beams look to be adjusted to High, and left beam not pointed more to center and lower. I'd love to see what the alignment looks like using original headlight aiming procedure.
My 64 coup has a show car stance (Not level, nose lower than rear, that makes me have to use about all the upward adjustment on them, but final adjustment meets original specs for original headlights. I don't use LED's. I do use Halogen Blue lights, an it still worries me that I'm blinding drivers in on coming cars.
My car does see a lot of night driving too.
Frankie,
I adjusted the beams the next day with the whole "25' on a level surface" manual technique and the beams dispersion is right on now....
I just never took a picture of it..
I took a 1-1/2 hour trip before daylight to a Melbourne car show a few months back with the lights on navigating an undivided rural country road for most of the trip and with all the opposing traffic I didn't get the "hi-lo beam flip" from irritated drivers going the other way...not once...
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,321 Likes
I use Search here quite a bit. And while going outside the site to Google is one of many ways to search, I rarely need to do that. The problem people generally have with the site search function is that they don’t use the “advanced” setting and enter parameters on that page.
I entered “LED lights” and specified all posts, within C1/2 and found the first 500 pretty quickly. To make it less unwieldy, I narrowed it to thread titles with “LED lights” only within C1/2. Of course, there’s lots of useful LED posts in C3 and by guys with the newer cars, so you can expand accordingly. You can also enter time frames as well.
I pretty much find everything I need in the site advanced search function when I tweak the parameters. “LED lights” within C1/C2 only, thread titles, returned 63 threads within 0.19 seconds, to start with (see below).
Like the obnoxious redhead on the Car Gurus Commercial, “whew, I’m beat.”
Frankie the Fink (03-20-2019)
Thank you for the tutorial. I didn't realize how simple it actually can be to find what you are looking for. I tried it and it works! I and a few of my friends have said in the past that the forum is a wealth of information but not friendly to work with. That's all changed.
Thanks again.
Thanks again.
vettebuyer6369 (03-20-2019)
I've found no better resource, online, for general and practical information for this marquee. I occasionally drift over to the NCRS forum if I went to know which of 10 shades a plated bolt should be or if an alternator should have caramel colored wafers between its halves...
