Dollar General oil class action lawsuit
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
I can’t imagine anyone here using this oil in any of their cars, but just in case:
https://topclassactions.com/lawsuit-...l-is-obsolete/
Steve
Steve
Popular Reply
03-27-2019, 07:09 AM
There are a lot of penny pinching cheapskates in this hobby. They'll never admit it, but I wouldn't be surprised. Now, where did I put that Harbor Freight box wrench, so I can change my Walmart battery??
The following 18 users liked this post by mike coletta:
59BlueSilver (03-27-2019),
arthursc2 (03-27-2019),
Chuck Gongloff (03-27-2019),
Cruzmeisters (03-27-2019),
Desert Nomad (03-27-2019),
and 13 others liked this post.
Received 6,519 Likes
C2 of Year Finalist (track prepared) 2019
Just speculating here.... since the oil isn't suitable for engines manufactured after 1988, I wonder if that is because the DG oil has high ZDDP levels which can damage catalytic converters. IOW, would this oil actually be good for our older engines with sliding surfaces?
The following 2 users liked this post by jim lockwood:
Dreaming60’s (03-27-2019),
rsinor (03-27-2019)
One of the DG oils they mention isn’t suitable for engines made after 1930. It must be REALLY awful stuff.
Steve
Steve
Back in the '60s, racers I knew built their engines with loose bearing clearances and used 50W to ensure good lubrication.
Received 5,524 Likes
I’m going to speculate that it is more the lack of additives (detergents, etc.) than more.
Class action attorneys....give the rest of us a bad rap. That said, the DG oil isn't "awful" necessarily because it's made inferior to what it should be, but because it's made to outdated API standards. DG isn't the only discounter selling API grade SA oil these days. Check out some of the stuff for sale under house brands in grocery stores, etc. Deceptive? I guess a jury is going to decide that, but everything you need to know is on the label, and it's just unsuitable for most engine uses.
https://www.api.org/products-and-ser...s#tab-gasoline
The 1988 and earlier standard is API grade SF. Some of the DG oils are made to API grade, which basically has no detergent or other additives. Yes, it's awful for use in a car engine, but because it's made that way not because it's made awfully. Many C1 and C2 owners could use something as outdated as API SD oil as you can see at the link. API grade SM and SN oils are the ones with low ZDDP and have the starbust logo on the can/bottle.
The following 2 users liked this post by Avispa:
SDVette (03-27-2019),
tuxnharley (03-27-2019)
St. Jude Donor '14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Steve
Steve
Received 5,008 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
“not suitable for use in most gasoline powered automotive engines built after 1988.”
(You guys go ahead and try it, and let me know how it works! )
If you go into a Dollar General to buy cheap motor oil for your $50,000+ car then you deserve what you get...
In such cases lawyers' jobs are to make you think anything you do, no matter how stupid, is someone else's fault....
The following 4 users liked this post by Frankie the Fink:
Brucebodyman (03-27-2019),
Hounddogjake (03-28-2019),
RatDog (03-27-2019)
I would use it for my lawnmower though..
Meh - much ado about nothing. One just has to use any product for its intended application. Nothing wrong with this oil for limited uses, nor with Harbor freight tools or Walmart batteries.
Plaintiffs Jason Wood and Roger Barrows of New York say they purchased DG Auto brand motor oil for several years. Plaintiff Wood also claims that he used that oil in his 2008 Chevy Colorado until the engine seized up in 2014.
Received 1,843 Likes
You could turn this thing around and allege that the API starburst oil that is sitting on the same shelf as other API rated oil could cause severe engine damage to older engines couldn't you?
Last I checked, WalMart had non detergent oil in their automotive department as well.
Looks to me like just lawyers trying to extort money out of business men. This is a bunch of phony baloney.
Received 3,443 Likes
My last two Walmart batteries (group 24's in my GTO's) lasted 17 years and 15 years respectively. They cost 29.95 each. Best car batteries I've ever owned, bar none. And the cheapest by far. They're $120 now.....
Larry
Seems to me that if a customer doesn't have enough sense to interpret an API label code, he should take his car to a garage and get his oil changed, don't you think? That API code is on the oil for a good reason.
Larry
Most of my hand tools are 50-70 years old. The rest are relatively new HF stuff. Thee roll around, double deck boxes full. The money I saved on tools helps me pay for $2000 paint jobs.
Guess that makes me a cheapskate?
The following 3 users liked this post by MikeM:
