corvette C1 with powerglide 350
Old 04-02-2019, 04:48 PM
Chuck Gongloff
CF Senior Member
Support Corvetteforum!
Chuck Gongloff's Avatar
Recieved 253 Likes on 200 Posts
Originally Posted by maguet11020 View Post
Tonawanda didn't make corvette block ?
No, all small blocks were cast in Flint/Saginaw, and had an "F" designation in the assembly stamping.
If you look at your block, I'll bet it has several embossed and debossed "T's" in the casting.
Many other differences too.. Others can elaborate..
Big blocks were cast in Tonawanda, NY.
Chuck Gongloff is offline
Old 04-02-2019, 06:18 PM
MikeM
CF Senior Member
Recieved 858 Likes on 728 Posts
Originally Posted by Chuck Gongloff View Post
Here's what I found. Would be for passenger car usage.
CU 1958 283 270 8 (dual quads) m/t, 3sp, hi lift cam
It's also listed for Corvette in 58, but the poster has a Tonawanda block, designated by the letter "T" in the assembly stamping, so it cannot be a Corvette block...
Well, it's not a TurboGlide block either so that answers the starter story. That also means that the block was never drilled for a starter motor. You should be able to drill the block if you have some kind of pattern or jig.
https://www.chevyhardcore.com/news/c...all-situation/
I don't remember the 283/270 engine being available in the '58 Pass car?
OP. Does your block have motor mount bosses on either side of the block? That's three holes, drilled/tapped for 3/8" bolts?
MikeM is offline
Old 04-02-2019, 06:40 PM
maguet11020
Junior Member
Recieved 1 Like on 1 Post
hi,
here, http://www.nastyz28.com/gm-chevy-cod...s-suffix-3.php , i see suffix CU 1958 vette.
on the left side, the is a mount bosse.
And there 3 holes in the block at the starter engine place ...
maguet11020 is offline
Old 04-02-2019, 07:19 PM
MikeM
CF Senior Member
A '58 Corvette engine block was not drilled for a block mounted starter nor did it have a 153 tooth flywheel like you are trying to match your starter motor with.
The 153 tooth flywheel and block mounted starter combination was not available on any SBC V-8 until 1963. It was first available on the 1962 Chevy II six cylinder and four cylinder engines. That won't help you.
I don't know what holes you have there. Somebody with an early block will have to help.
MikeM is offline
Old 04-02-2019, 07:38 PM
Chuck Gongloff
CF Senior Member
This thread should help you understand the difference between Flint and Tonawanda blocks.
https://www.corvetteforum.com/forums...nda-block.html
The CU suffix was also used for 2x4 carbureted passenger cars.
http://www.chevy-camaro.com/chevy-ca...es.asp?group=2
Old 04-02-2019, 09:10 PM
jim lockwood
CF Senior Member
jim lockwood's Avatar
Recieved 533 Likes on 387 Posts
It might be time to just get out the drill and the tap and die set and make it all work.
jim lockwood is offline
Old 04-03-2019, 02:04 AM
maguet11020
Junior Member
you are right! just the time to find imperial stuff !
thanks for your advices , i will be back back when it is done .;
Pascal
Old 04-03-2019, 07:06 AM
emccomas
CF Senior Member
emccomas's Avatar
Recieved 649 Likes on 368 Posts
One other option is the 1/4 thick adapter plate to mount a front mounted starter.
Here is a link to one of them. I used one of these in the past and it worked fine.
https://www.ebay.com/itm/Chevy-Engin...YAAOSwPVFcQAog
Personally, I would drill and tap the block for a 63 and up starter.
emccomas is offline
Old 04-03-2019, 07:07 PM
knockbill
CF Senior Member
knockbill's Avatar
Recieved 2 Likes on 2 Posts
Drilling and tapping the block will work, as discussed... I did it on a PG to T350 swap on a 350 engine,,, but that had one bolt in the proper place, for the T350 flywheel, so alignment of the starter/flywheel teeth was correct,,, With the 283, there wont be any starter holes in the block for alignment, so you start from scratch,,, not sure how to insure the block hole location will be right,,, unless there is a template available?
knockbill is offline
Old 04-03-2019, 07:38 PM
jim lockwood
CF Senior Member
I typically use the TLAR method.
Old 04-03-2019, 07:51 PM
emccomas
CF Senior Member
emccomas's Avatar
You have two holes there now. Get a 63 and later starter and see if one of the holes lines up for the starter and flexplate.
Plan B would be to get a template from a 63 or later block.
Check out the video, should answer all of the questions.
emccomas is offline
Old 04-04-2019, 02:01 AM
maguet11020
Junior Member
oh bad news !
I Was thinking to use the external hole to align my starter engine to the flywheel !
i’m out of the office this week ....let see next week .
would you like to give me the drill and Die set dimension ? I’m not familiar with the impérial
system ?
There are 2 thread types , isn’t it ?
Old 04-04-2019, 02:04 AM
  #33
maguet11020
Junior Member
thanks for sharing ! It seems easy
https://www.youtube.com/watch?v=z6aj_09yEk4
thanks for sharing
Old 04-04-2019, 07:12 AM
  #34
knockbill
CF Senior Member
knockbill's Avatar
oh bad news !
system ?
Bottom mount (vertical ) starter bolts are 3/8-16.... Drill size is 5/16" If there are three tapped holes there, bolt a starter with one bolt and mount the flywheel, see if they mesh smoothly by hand...If so, drill a new hole where its needed... I used a long 5/16" bit and used the starter as a guide,,,, But that was 30years ago!!!! I don't have that engine or an early 283 to look at now...
Old 04-04-2019, 12:30 PM
  #35
maguet11020
Junior Member
thanks, is it UNC or UNF ?
Old 04-04-2019, 12:36 PM
  #36
MikeM
CF Senior Member
It is UNC and on top of that. Requires special shouldered bolts to keep the starter square with the holes. If you try to use plain bolts, the starter can rotate around the bolts.
This is a similar image.
MikeM is offline
Old 04-04-2019, 12:47 PM
  #37
maguet11020
Junior Member
ok ! so i must order : 2 drill 5/16.
1 die 3/8 UNC !
Old 04-04-2019, 01:23 PM
  #38
knockbill
CF Senior Member
knockbill's Avatar
3/8-16 is coarse,,, you don't need a die,,, you need a tap... And those starter bolts, if you don't have them...
Old 04-04-2019, 05:45 PM
  #39
maguet11020
Junior Member
what do you mean ? I need à Die set !
Old 04-04-2019, 09:08 PM
  #40
JohnZ
CF Senior Member
Recieved 1,003 Likes on 666 Posts
Nope. Dies are for cutting male threads on round stock, and that's not what you're doing - you're drilling a hole and using a tap to cut female threads in the hole.
Also note that the starter bolts in post #36 are knurled (to slightly increase their diameter) where the round bolt shank ends, just before the threads start - that's to provide a close-tolerance "pilot" to center the starter bolt in the hole in the starter flange to properly align the starter casting to the block.
JohnZ is online now
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
