Electrical ?
Old Apr 6, 2019 | 12:57 PM
Vette5311's Avatar
Vette5311
Default Electrical ?
Ok this may sound silly but I'm no sparky. I bought a battery spade quick disconnect and am wondering should it go on the B+ battery post or the ground (-) post. The positive is easier to get to(C2) but will it spark when connecting if on B+. Thanks in advance for the help.
Old Apr 6, 2019 | 01:03 PM
JohnFromVentura's Avatar
JohnFromVentura
Always put the disconnect on the negative side!
Fatdaddy's Avatar
Fatdaddy
I have mine on the ground side,no sparks that way
Old Apr 6, 2019 | 01:10 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Negative And on mine it only fits on the negative terminal
Old Apr 6, 2019 | 01:19 PM
Vette5311's Avatar
Vette5311
Default Ok
Thanks guys. That's what I thought.
Old Apr 6, 2019 | 01:24 PM
tbarb's Avatar
tbarb
And you said you were no sparky... :-)
Old Apr 6, 2019 | 07:34 PM
Vette5311's Avatar
Vette5311
I sometimes surprise myself but not always in a good way. . I have learned as I've aged to seek advice.
Old Apr 7, 2019 | 09:32 AM
C2Dude's Avatar
C2Dude
So I need schooling here, mine is on the positive side. No sparks that I can see when connecting it. Is that the concern or am I inviting other problems??
Old Apr 7, 2019 | 11:07 AM
65GGvert's Avatar
65GGvert
Whether it's on the positive or negative, it does the same thing. It interrupts the completed circuit so that no current can flow. The only negative I have run into with the cutoff on the positive is (particularly with the large blade type) even when open you have a fairly large chunk of metal sticking up that has 12v on it and you still have the ground connected. If you drop a wrench or something metallic and it touches the ground (like engine or exhaust manifold) and falls into the cutoff, you get 12v directly to ground. You also get a large fireworks display and some hot metal. If this sounds oddly specific, it is. It happens.
With the cutoff on the negative side, shorting the positive side to ground will do nothing, and shorting to the negative side only reconnects the battery. For that reason alone, I do the negative side.
Old Apr 7, 2019 | 12:37 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Which is the whole reason the cutoffs are sized for the negative terminal.
Old Apr 7, 2019 | 01:00 PM
Vette5311's Avatar
Vette5311
So I did some research after posting this question. The biggest potential problem comes from hydrogen gas (think Hindenberg). If the cutoff is on the positive side and any current is flowing when you disconnect it with the ground connected, it will spark. Maybe not large enough to see but a discharge non the less. Now if the battery is venting or overcharging hydrogen gas, which is very flammable, is produced. AND the spark will ignite it. If you have ever seen a battery explosion, it is not a pretty thing, and you better pray you have your safety glasses on. Not just damage to the car and paint, but personal injury can and will result. Now that is the schooling lesson for today. Thanks to all for the responses. Happy motoring.
Old Apr 7, 2019 | 01:07 PM
C2Dude's Avatar
C2Dude
Well I had a 50/50 chance of getting it right. Some day, odds are, I'll get it right the first time.
Old Apr 7, 2019 | 01:17 PM
65GGvert's Avatar
65GGvert
You are mistaken if you think you won't get any spark at all when you reconnect the negative post. Particularly if the doors are open or any other electronic device is on
Old Apr 7, 2019 | 01:27 PM
Vette5311's Avatar
Vette5311
Yes, I see, current is flowing either way, makes sense. Thanks
To Electrical ?
