Zinc added to oil
Old 04-09-2019, 06:01 PM
raylag64
CF Senior Member
Recieved 12 Likes on 12 Posts
Shell Rotella T with ZDDP for flat tappet cams
raylag64 is offline
fjd (04-09-2019)
Old 04-09-2019, 06:59 PM
MikeM
CF Senior Member
Recieved 858 Likes on 728 Posts
Originally Posted by Nowhere Man View Post
The whale oil is a old time GM tech slang term for the posi additive
MikeM is online now
Old 04-09-2019, 07:08 PM
jim lockwood
CF Senior Member
jim lockwood's Avatar
Recieved 533 Likes on 387 Posts
Originally Posted by 62cruiseer View Post
So, diesel oil, like Rotella, already has the zinc added or it's not needed? And, just run the same weight diesel oil as you would with other oil, 10-40 or 10-30? Sorry, learning something here.
Butch
Yes. This:
Originally Posted by GTOguy
The Rotella and similar diesel spec oils already have the higher ZDDP
jim lockwood is online now
Old 04-09-2019, 07:10 PM
Nowhere Man
CF Senior Member
Nowhere Man's Avatar
Recieved 1,576 Likes on 1,410 Posts
2015 C2 of Year Finalist
Originally Posted by MikeM View Post
my relative who worked as a tech in the 70's calls it whale sperm. the first time he told he asked for that while working on a rear I had to stop and double check that I herd that right and he laughed and told me.
Nowhere Man is online now
Old 04-09-2019, 07:29 PM
MikeM
CF Senior Member
Sperm whale oil. When Sperm whales became protected, the formula had to change.
MikeM is online now
Old 04-09-2019, 07:39 PM
ditchdigger650
CF Senior Member
ditchdigger650's Avatar
Recieved 4 Likes on 4 Posts
I’ve been using Brad Penn 10-30 for years now, no issues. The green oil, for flat tappet cams.
ditchdigger650 is offline
Old 04-09-2019, 09:09 PM
richopp
CF Senior Member
richopp's Avatar
Recieved 24 Likes on 20 Posts
Best I can do on this:
http://www.straightdope.com/columns/...ith-whale-oil/
A month or so ago a guy had a case of it for sale somewhere online; it wasn't all that expensive, as I remember. I guess if you have a lot of older cars like the gentleman I bought my '66 from, buying a case of whale oil makes sense if you wish to use it in those cars.
Cheers,
Richard
richopp is offline
Old 04-10-2019, 10:36 AM
SWCDuke
CF Senior Member
Recieved 531 Likes on 366 Posts
Most of the internet engine oil conversations you read are full of myths, misinformation, and marketing hype. It you want FACTS and a logical way to make a decision, search for threads started by me, download and read the engine oil pdf. You might even consider giving a copy to your mechanic.
I think the name "whale sperm" was from the fact that the little four-ounce bottle was so expensive. Prior to the USA outlawing whale products in the 1970s the Positraction additive was some form of whale oil, but I'm not sure what species. There was also some in the old Type A Suffix A ATF.
So the industry had to develop a synthetic substitute, which is probably a good thing because oils from living things like whales and castor beans break down much more rapidly at operating temperatures than synthetics.
Duke
SWCDuke is offline
Old 04-10-2019, 10:43 AM
reno stallion
CF Senior Member
Recieved 96 Likes on 72 Posts
Stop stepping over a dime to save a nickel just buy good oil that is designed for flat tappet cams
reno stallion is online now
Old 04-10-2019, 10:52 AM
buckybadger45
Junior Member
Recieved 0 Likes on 0 Posts
I have been using Penn Grade 1, which is the old Kendall GT and Brad Penn oil. It's had several name changes but is still called the "original green oil". I have verified by calling the company. It has plenty of ZDDP and I've never had a problem. No additives needed.
buckybadger45 is offline
Old 04-10-2019, 10:58 AM
reno stallion
CF Senior Member
Originally Posted by ditchdigger650 View Post
Iíve been using Brad Penn 10-30 for years now, no issues. The green oil, for flat tappet cams.
My Ferrari buddy told me about Brad Penn oil I thought he was joking. I will have to research it
FINWOLF
CF Senior Member
FINWOLF's Avatar
this what I use for the last 5 years
Valvoline SAE 30 VR1 Racing Motor Oil
  • High zinc/phosphorus for anti-wear protection, including push-rod and flat tappet applications
  • Formulated to increase horsepower
  • Enhanced anti-foam system protects engine during extreme stress
  • Recommended for engines burning gasoline and full or partial alcohol fuels
  • For any product use or product technical questions call 1-800-TEAM-VAL
FINWOLF is offline
Old 04-10-2019, 11:08 AM
  #33
GTOguy
CF Senior Member
Support Corvetteforum!
GTOguy's Avatar
Recieved 1,102 Likes on 863 Posts
The racing oil doesn't have the needed additive packages to combat corrosion in a street driven engine. Great for the track, where it's dumped after a day of racing, but not so great in the crankcase for 6 months in a street driven car.
GTOguy is offline
Old 04-10-2019, 01:56 PM
  #34
jim lockwood
CF Senior Member
You don't want to run racing oil in a street engine. It's designed for a completely different environment.
Old 04-10-2019, 02:01 PM
  #35
MikeM
CF Senior Member
Lot's of owner's seem to think this is the way to go, unfortunately.
MikeM is online now
Old 04-10-2019, 03:45 PM
  #36
GTOguy
CF Senior Member
GTOguy's Avatar
Yep. More is always better, and since a Corvette is a high performance car, racing oil must be just the ticket! Sadly, many owners of high performance cars feel this way. Oh well....it'll keep the parts houses and mechanics in business.
GTOguy is offline
fjd (04-10-2019)
Old 04-10-2019, 03:51 PM
  #37
Frankie the Fink
CF Senior Member
Frankie the Fink's Avatar
Recieved 3,517 Likes on 2,778 Posts
I put racing oil in the same category as driving gloves. Nothing exudes coolness like gloves when you gas up at 7-11.
Frankie the Fink is offline
Old 04-10-2019, 04:03 PM
  #38
jim lockwood
CF Senior Member
I always wear my leather driving shoes when I go out in one of my 4 speed cars because their design makes it easier to do heel and toe downshifts. I doubt that anyone who sees them realizes how cool they actually are.
fjd (04-10-2019)
Old 04-10-2019, 04:38 PM
  #39
Frankie the Fink
CF Senior Member
Yeah. Flip-flops are really cool here in Florida too.
And gold chains.
Old 04-10-2019, 04:41 PM
  #40
MikeM
CF Senior Member
Color keyed socks to match your shorts.
MikeM is online now
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
