Zinc added to oil
#41
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
#42
Received 1,518 Likes
C2 of Year Finalist (appearance mods) 2019
Not quite sure what kind of racing oil you guys are talking about but the post and picture of the label on the driven [Joe Gibbs Racing Oil] Says it all read it
#44
Received 6,943 Likes
2015 C2 of Year Finalist
#45
Nice, what weight are u using?
#47
Corvette Paramedics in NJ charges about $165 for an oil change for a C2 with the zinc additive.
#48
#49
That's what I thought. I dont want to pay that, its more than I pay Audi to do my RS5 oil change.
So just to wrap, consensus is:
What is the consensus if I do this myself? Many answers here.
Frank
- You need something or not? Zddp?
- Use Rotella or use Valvoline with zinc or Amsoil Z rod, Hot Rod Motor Oil with Zinc, Brad Penn Oil?
Frank
#50
Go to a store find a oil with a. API ratting of CK-4. Buy five quarts or six depending what oil pan you got. That’s roughly 4.50 a quart. Then get a filter. You should have no more then 35 dollars in a oil change
#51
Weight?
#52
fjd (04-11-2019)
#53
Frank
Frank
fjd (04-11-2019)
#54
There are four things to take away from the discussion of oil for our older engines:
1. If the engine has stock valve train, meaning stamped steel rocker arms and a flat tappet cam, the engine needs oil with ZDDP
2. There is such a thing as too much ZDDP. In excess quantities it causes an obscure and poorly understood form of internal corrosion.
3. Racing oil has appropriate levels of ZDDP but it lacks other ingredients needed by street driven engines.
4. Diesel oil has appropriate levels of ZDDP and is inexpensive.
Jim
Jim
#55
Great which Diesel, Rotella with c4? What weight? Thanks!
#56
#57
#58
Received 1,974 Likes
#59
Received 3,443 Likes
II had to go back to post 28. I hadn't read it. "Whale Sperm" is deceptive....the old whale oil used in oil lamps for illumination and later, in the petroleum industry for fine quality lubrication needs actually came from the sperm whale, which has a huge waxy deposit of fat containing this oil in it's forehead. The finest stuff available in the natural world. So the oil isn't 'whale sperm', wasn't named that because it was expensive later on, but because it did, in fact, come from the waxy forehead deposits of sperm whales.
#60
Gloves help a lot on a hot day when things get sweaty and slippery. Grip on the steering wheel and shift **** is nice to have! Not everybody has AC in our midyears.....
