Zinc added to oil
Old 04-11-2019, 09:20 PM
  #81
Frankie the Fink
CF Senior Member
Support Corvetteforum!
Frankie the Fink's Avatar
Liked 3,499 Times in 2,767 Posts
Originally Posted by fjd View Post
OK we are off the rails here. Pray I dont create a new thread about the squeak coming from the left rear now. When I rock it. I know I know, pics. Could be bushings, springs, shock, gremlins.
Some think quoting costs for parts and work from 70 years ago carries some relevance today. It doesn’t.
Frankie the Fink is online now
Old 04-11-2019, 09:29 PM
  #82
Powershift
CF Senior Member
Liked 627 Times in 569 Posts
Don't be so hard on Mike..........I think he was talking about 55 years ago. Yes, times have changed, but $165 for an oil and filter change is still to much for these old Chevies. But for a new Porsche Boxster it is about the norm.
Larry
Powershift is online now
Old 04-11-2019, 09:46 PM
  #83
tuxnharley
CF Senior Member
tuxnharley's Avatar
Liked 618 Times in 505 Posts
“Those who fail to learn from history are doomed to repeat it.”
Historical data is relevant when scaled proportionally.
tuxnharley is offline
Old 04-11-2019, 10:04 PM
  #84
Tigershark3
CF Senior Member
Tigershark3's Avatar
Liked 13 Times in 13 Posts
Originally Posted by ditchdigger650 View Post
I’ve been using Brad Penn 10-30 for years now, no issues. The green oil, for flat tappet cams.
Tigershark3 is offline
Old 04-12-2019, 08:08 AM
  #85
MikeM
CF Senior Member
Liked 854 Times in 724 Posts
Spraying the bushings with rubber lube used to be part of the $1 lube job!
Swing by that specialty Corvette shop and get an estimate on how much they'll charge to diagnose your problem.
MikeM is offline
Old 04-12-2019, 08:49 AM
  #86
Frankie the Fink
CF Senior Member
85 posts on engine oil!
Who says the good times are gone forever?
Old 04-12-2019, 09:00 AM
  #87
fjd
CF Senior Member
fjd's Avatar
Liked 6 Times in 6 Posts
I can only imagine. Diagnosis fee, road test fee, high pitch frequency test fee.
fjd is offline
Old 04-12-2019, 09:02 AM
  #88
Frankie the Fink
CF Senior Member
OBD-II scan, adjusting the glublink, and replacing the ratafrat.
The following users liked this post: Frankie the Fink
fjd (04-12-2019)
Old 04-12-2019, 09:07 AM
  #89
jim lockwood
CF Senior Member
jim lockwood's Avatar
Liked 531 Times in 386 Posts
So after 87 helpful replies, have you decided what to do about your oil dilemma?
Expiring minds want to know.....
jim lockwood is offline
Old 04-12-2019, 09:13 AM
  #90
MikeM
CF Senior Member
Who couldn't see this coming? See post #3.
MikeM is offline
Old 04-12-2019, 09:36 AM
  #91
fjd
CF Senior Member
fjd's Avatar
I've decided to use.............
Rotella T5 Synthetic Blend Diesel Motor Oil, 15W-40 w/CK-4,
That is until the franastan breaks.
fjd is offline
The following users liked this post: fjd
jim lockwood (04-12-2019)
Old 04-12-2019, 12:37 PM
  #92
vetsvette2002
CF Senior Member
Liked 70 Times in 60 Posts
St. Jude Donor '13-'14-'15-'16
Make double sure you use the correct left handed metric crescent wrench on the drain. Failure to do so will void your warranty.
vetsvette2002 is offline
The following users liked this post: vetsvette2002
fjd (04-12-2019)
Old 04-15-2019, 06:45 PM
  #93
Dad's '66 427
CF Senior Member
Dad's '66 427's Avatar
Liked 63 Times in 37 Posts
Does anyone have experience with this oil?
Dad's '66 427 is offline
Old 04-15-2019, 06:48 PM
  #94
GTOguy
CF Senior Member
GTOguy's Avatar
Liked 1,098 Times in 860 Posts
Yep. I've used it. Works just fine.
GTOguy is offline
Old 04-15-2019, 07:19 PM
  #95
tuxnharley
CF Senior Member
tuxnharley's Avatar
Same here, I use it in both my diesel rigs and my old cars. Available at Costco at a great price!
Old 04-15-2019, 11:27 PM
  #96
John BX NY
CF Senior Member
Liked 82 Times in 67 Posts
I like the Rotella because it leaves less stains on the floor of my garage compared to full synthetic. Old unrestored cars tend to leak just like their owners.
John BX NY is offline
Old 04-16-2019, 03:08 AM
  #97
SDVette
CF Senior Member
SDVette's Avatar
Liked 335 Times in 242 Posts
2016 C1 of Year Finalist
Not to stir the pot (!).. but according to Chevron, the zinc content in the Chevron Delo CK-4/SN oil is .08%, which is 800 ppm.
https://cglapps.chevron.com/sdspds/P...&docFormat=PDF
While Shell Rotella T appears to have 1200 ppm (https://en.wikipedia.org/wiki/Shell_Rotella_T), which is 50% more than the Chevron.
SDVette is online now
Old 04-16-2019, 08:08 AM
  #98
SWCDuke
CF Senior Member
Liked 529 Times in 364 Posts
Yes, I've looked at various CK-4 spec sheets and some have reduced P and Zn, which means less ZDDP. Further research revealed that ZDDP has been supplemented by a new Boron-based anti-wear additive, but the spec sheets don't list Boron concentration.
All C-category oils have to pass the same tests, including the anti-wear test, so the reduced ZDDP doesn't bother me, but I wish the spec sheets included Boron concentration. The important thing to remember is that CK-4 is said by all blenders to be "fully backward compatible" with all prior C-categories, so CK-4 is as good as prior categories in terms of wear protection for sliding surface valve train components, despite some having less ZDDP.
Duke
SWCDuke is offline
The following users liked this post: SWCDuke
tuxnharley (04-16-2019)
Old 04-16-2019, 11:21 AM
  #99
Muttley
CF Senior Member
Muttley's Avatar
Liked 29 Times in 26 Posts
Potentially adding to the confusion, Shell is now marketing a Rotella-branded oil "for gasoline pickups". This new product appears to be an SN-rated oil, not a C category oil. So always check the label.
Muttley is offline
Old 04-16-2019, 12:35 PM
  #100
tuxnharley
CF Senior Member
tuxnharley's Avatar
Boron - who knew? I learn something new everyday here on the Forum!
IIRC the zinc and phosphorus content was reduced because those amounts that made it through the combustion process became a contaminant in the catalytic converters and reduced their efficiency. I wonder how Boron acts in that regard?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
