Zinc added to oil
#101
Received 1,843 Likes
Remeber this?
#102
Back in the 1960's and early 1970's, Boron Trifluoride (BF3) was used in the reaction to make mixed alkyl fluid (MAF) when mixing TEL and TML organic leads. Some oil companies preferred the full spectrum of these organic leads versus just using TEL. Mobil was one and Chevron was another.....and there were likely a few more.
We supplied TEF (TEL + lead scavengers) as well as MAF (mixed alkyls + lead scavengers) as needed to the various oil companies for their gasoline. There were probably a total of about 8-12 different blends in all. I have no idea if one was really better than the other, but the MAF ones certainly contained Boron in the mix.
Larry
Larry
#104
The last time I had even thought about Boron was when I drove thru/past the “town” of that name on my way to Vegas!
#105
Received 3,443 Likes
I bought a huge carton of Boraxo Hand Soap (the 20-mule-team-powdered stuff they used to have at gas stations) about 15 years ago, and still have a bunch of it. Used it this week to clean grease off my hands. Still works great! Go by Boron every year on my way to Panamint Valley....they have a neat museum there. Affordable housing, too, for CA! lol.........
#106
Should I put powdered Borax in my crankcase to make it more slippery for moving parts? Just curious.
#107
No, but it used to be a treatment for seating rings!
#108
I thought that was Bon Ami cleanser.....but then again, odds are that Bon Ami contains Boron!!! And Mike, you should do whatever you did back in 1957. It's worked so far!!
#109
You’re probably right - I may have confused the two!
#110
Pro Mechanic
Received 1,302 Likes
2023 C1 of the Year Finalist - Modified
I have a pending appointment at a "vette specialty" shop in NJ. They are telling me I should get an oil change and that they need to add a zinc additive for my cam? BS or true? I've seen a lot on oil here and nothing on zinc. It jacks up the price of the oil change by almost double. My local mechanic says its nonsense.
Frank
Frank
