Zinc added to oil
fjd (04-09-2019)
Received 1,843 Likes
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
Yes. This:
Originally Posted by GTOguy
The Rotella and similar diesel spec oils already have the higher ZDDP
Received 6,943 Likes
2015 C2 of Year Finalist
Sperm whale oil. When Sperm whales became protected, the formula had to change.
http://www.straightdope.com/columns/...ith-whale-oil/
A month or so ago a guy had a case of it for sale somewhere online; it wasn't all that expensive, as I remember. I guess if you have a lot of older cars like the gentleman I bought my '66 from, buying a case of whale oil makes sense if you wish to use it in those cars.
Cheers,
Richard
Received 1,974 Likes
Most of the internet engine oil conversations you read are full of myths, misinformation, and marketing hype. It you want FACTS and a logical way to make a decision, search for threads started by me, download and read the engine oil pdf. You might even consider giving a copy to your mechanic.
I think the name "whale sperm" was from the fact that the little four-ounce bottle was so expensive. Prior to the USA outlawing whale products in the 1970s the Positraction additive was some form of whale oil, but I'm not sure what species. There was also some in the old Type A Suffix A ATF.
So the industry had to develop a synthetic substitute, which is probably a good thing because oils from living things like whales and castor beans break down much more rapidly at operating temperatures than synthetics.
Duke
Duke
I have been using Penn Grade 1, which is the old Kendall GT and Brad Penn oil. It's had several name changes but is still called the "original green oil". I have verified by calling the company. It has plenty of ZDDP and I've never had a problem. No additives needed.
this what I use for the last 5 years
Valvoline SAE 30 VR1 Racing Motor Oil
- High zinc/phosphorus for anti-wear protection, including push-rod and flat tappet applications
- Formulated to increase horsepower
- Enhanced anti-foam system protects engine during extreme stress
- Recommended for engines burning gasoline and full or partial alcohol fuels
- For any product use or product technical questions call 1-800-TEAM-VAL
#33
Received 3,443 Likes
The racing oil doesn't have the needed additive packages to combat corrosion in a street driven engine. Great for the track, where it's dumped after a day of racing, but not so great in the crankcase for 6 months in a street driven car.
#34
You don't want to run racing oil in a street engine. It's designed for a completely different environment.
#35
#36
Yep. More is always better, and since a Corvette is a high performance car, racing oil must be just the ticket! Sadly, many owners of high performance cars feel this way. Oh well....it'll keep the parts houses and mechanics in business.
fjd (04-10-2019)
#37
I put racing oil in the same category as driving gloves. Nothing exudes coolness like gloves when you gas up at 7-11.
#38
I always wear my leather driving shoes when I go out in one of my 4 speed cars because their design makes it easier to do heel and toe downshifts. I doubt that anyone who sees them realizes how cool they actually are.
fjd (04-10-2019)
#39
And gold chains.
#40
Color keyed socks to match your shorts.
