[C1] 1954 oil pump issue
Old 04-14-2019, 04:23 PM
keeks2915
CF Senior Member
Recieved 147 Likes on 41 Posts
Default 1954 oil pump issue
Getting all the vettes out of storage, bumper to bumpers, and LOF.
While going through 54, it starts up great. (Just rebuilt and body off last year)
Oil pressure gauge shows 0 Oil pressure, so we cut it immediately. Hooked up independent oil pressure tester and no pressure.
Pulled pan and pulled apart pump. “Impellers had some small gouging on fins and some clear scoring on pump wall.
Ran air through and no blockages otherwise.
So..... thankfully having a son who is licensed mechanic, knew to cut her off quick and no damage.
Need to source a new oil pump, (doesn’t have to be NCRS as this isn’t a judged car) just need something that will work properly.
But. The one part of pump seems attached with round fasteners to block that I have no idea how to remove...
any help or advice?
keeks2915 is offline
Old 04-14-2019, 05:23 PM
Chuck Gongloff
CF Senior Member
Support Corvetteforum!
Chuck Gongloff's Avatar
Recieved 254 Likes on 200 Posts
The bottom of the distributor has a straight edge, like the end of a flat bladed screwdriver. That "tang" has to engage the slot in the oil pump rod.
The distributor drives the oil pump. If the distributor has walked up and out of it's clamp somewhat, the oil pump will not be driven.
Don't ask me how I know this.
Chuck Gongloff is offline
Old 04-14-2019, 05:35 PM
cardo0
CF Senior Member
cardo0's Avatar
Recieved 209 Likes on 200 Posts
Both Melling and Sealed Power still sell replacement pumps - at your local parts stores or even Rock Auto has them on-line. But the "pressurized oil system" of the "stove bolt sixes" where frequently upgraded from a "bypass oil system" to a "full flow system" and even a spin on oil filter. Take a look: http://devestechnet.com/home/thevenerable261
and: http://devestechnet.com/Home/FullFlowOil
Hope this helps.
cardo0 is offline
Old 04-14-2019, 07:58 PM
keeks2915
CF Senior Member
Thanks....added some photos... will check distributor
Old 04-14-2019, 08:42 PM
keeks2915
CF Senior Member
Chuck..... I cant thank you enough.......we raced over to shop and sure as shi% the distributor did walk up.... you can see on the pump shaft scoring on the top edge of the slot. So we will make sure the distributor is full seated and locked down better. Owe you a big dinner Chuck!
Old 04-15-2019, 04:03 AM
R66
CF Senior Member
R66's Avatar
Recieved 287 Likes on 249 Posts
Did you check the rod and main bearings for scoring from the metal you found in the pump?
R66 is offline
Old 04-15-2019, 05:34 AM
Chuck Gongloff
CF Senior Member
Glad I could help you out.
Old 04-15-2019, 07:51 AM
csherman
CF Senior Member
csherman's Avatar
Recieved 240 Likes on 200 Posts
2018 C1 of Year Finalist
a big cause of oil pump damage is the mis alignment of the dist and the oil pump
alot of people install the pump then install the dist later
it puts a ton of side load on the pump
keep the dist loose and pump loose - after both are installed - THEN tighten them up
like chuck - dont ask how I know.....
and yes - these are known to walk up....keep the advance tight
csherman is offline
Old 04-15-2019, 09:18 AM
keeks2915
CF Senior Member
Filtered oil and found zero particles or significant residue. But will inspect the bearings for scoring as well. Thanks
Old 04-15-2019, 09:19 AM
keeks2915
CF Senior Member
Thanks chris..
Old 04-15-2019, 02:58 PM
mkh
CF Senior Member
mkh's Avatar
Recieved 4 Likes on 2 Posts
Read chrisís Post carefully. My engine builder on my 54 installed the oil pump without the distributor in it as it was out for rebuild. When I installed the distributor in the freshly rebuilt engine it ran for about 10 seconds and ate the distributor gear and cam gear up. Had to pull the engine and rebuild it along with the distributor. Very costly mistake!!!!
mkh is offline
Old 04-15-2019, 03:27 PM
csherman
CF Senior Member
csherman's Avatar
Yep
it will eat them up in a heartbeat !!!
You have to align them
csherman is offline
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
