Ď64 Battery
Old 04-15-2019, 08:51 AM
64 Silver Blue
CF Senior Member
64 Silver Blue's Avatar
Recieved 3 Likes on 3 Posts
Default Ď64 Battery
I recently returned from winter in Florida to find a dead battery in my 1964 non-air convertible. Iím not sure how that happened as I had a battery tender, but thatís another story. I took the dead battery to Battery Warehouse for a replacement. I had ordered a replacement set of battery cables a while ago, but hadnít replaced them yet, and figured this would be a good time. I found the cables didnít fit in the car with the battery terminals oriented. The car has been thoroughly gone over by bubba. When I purchased the car the battery was held in with a bungee cord! I purchased a battery box and hold down hardware and the battery cables, but the battery cable didnít seem to be the correct length, so I tossed them on the shelf.
I took a close look yesterday, and It looks like if the battery terminals were reversed the battery cables would reach the correct terminals. I suspect I have purchased the wrong battery. The battery is installed with the two terminals closest to the firewall and the positive terminal closest to the engine and the ground closest to the fender. The red battery cable is longer than the black cable, and would reach the outboard end of the battery, and the shorter black cable would reach the ground terminal, if it were on the inboard side. If this explanation is too confusing Iíll shoot a photo.
Gene
64 Silver Blue is offline
Old 04-15-2019, 09:07 AM
MikeM
CF Senior Member
Recieved 858 Likes on 728 Posts
Gene
What's confusing to me is, why don't you just turn the battery 180*?
MikeM is online now
Old 04-15-2019, 09:27 AM
64 Silver Blue
CF Senior Member
If I reverse the battery 180* it puts the terminal posts on the forward side of the battery. Than the cables won’t reach the terminal posts. I guess what I need is a photo of an unmolested 1964 car with the correct battery.
Old 04-15-2019, 09:31 AM
Nowhere Man
CF Senior Member
Nowhere Man's Avatar
Recieved 1,576 Likes on 1,410 Posts
2015 C2 of Year Finalist
Group 24 is the battery you want. And should have the post where you want them
Nowhere Man is online now
Old 04-15-2019, 09:37 AM
64 Silver Blue
CF Senior Member
A group 24 is what I bought. Are there different part numbers that reverse the positive and negative posts?
Old 04-15-2019, 09:42 AM
Nowhere Man
CF Senior Member
yes there are but I dont know what they are.
Old 04-15-2019, 09:51 AM
MikeM
CF Senior Member
There is a 24 and 24 F. You can see the terminals are reversed.
MikeM is online now
Panama 58
CF Senior Member
Panama 58's Avatar
Recieved 92 Likes on 87 Posts
Gene, here is the orientation you want. This is my '64. If you have a 24 battery, then I would check your cables. My black cable is the positive and is significantly shorter than the brown negative cable. I know some guys like their positive cable to be red, but it sounds like your cables are for a different series battery.
Panama 58 is offline
Old 04-15-2019, 10:03 AM
64 Silver Blue
CF Senior Member
Your photo shows exactly the same terminal layout as my battery. Curiously, you said your ground cable is brown and the positive cable is black. I assumed (incorrectly I guess) that the brown cable was a muted red and positive, and the black cable is ground. If the cables are reversed they will fit perfectly.
Thanks of the photo! I really don’t care too much how original things are as I don’t go to shows, but as long as I’m fixing things I’d like to return things to as close to stock as possible.
Gene
Old 04-15-2019, 10:17 AM
Nowhere Man
CF Senior Member
Original and repro battery cables have a + and - sign on the cable ends. Go by that and not the color of the cable. And you can always double check where that cable goes to be sure
Old 04-15-2019, 10:31 AM
MikeM
CF Senior Member
Gene
Did you see post #7?
MikeM is online now
64 Silver Blue (04-15-2019)
Old 04-15-2019, 10:40 AM
65GGvert
CF Senior Member
65GGvert's Avatar
Recieved 1,119 Likes on 984 Posts
Original cables, black is positive. Brown is ground. If I understand your post, the cables will fit in that orientation. If so, you're done.
65GGvert is offline
Old 04-15-2019, 10:45 AM
64 Silver Blue
CF Senior Member
Yes, I did see your photo Mike, thanks so much.
I checked the photo Panama 58s posted. My battery has the same terminal layout at the 24, not the 24F. I looked at the cables closely, and the brown cable has a big N on the spring ring end. The black cable may be marked too, but heat shrink covers the same area as the N on the brown cable, so my guess is I had the positive and negative cables reversed.
Old 04-15-2019, 10:51 AM
64 Silver Blue
CF Senior Member
Thanks for all your help everyone, problem solved. Every time I post a question on the Forum the solution sure makes me look dumb. If the shoe fits, wear it. At least the problem is solved.
Gene
Old 04-15-2019, 10:54 AM
426 Hemi
CF Senior Member
426 Hemi's Avatar
Recieved 263 Likes on 180 Posts
I think there's an inner diameter difference between the two clamps also.
426 Hemi is offline
sidepipe seeker (04-16-2019)
Old 04-15-2019, 11:40 AM
sidepipe seeker
CF Senior Member
Support Corvetteforum!
Recieved 59 Likes on 42 Posts
Gene
....What gives you a bountiful lead ahead of others Gene, is your ability to recognize that you are in need of assistance & seek out that of which you wish to find!...Mark..
sidepipe seeker is offline
Old 04-15-2019, 02:00 PM
Frankie the Fink
CF Senior Member
Frankie the Fink's Avatar
Recieved 3,517 Likes on 2,778 Posts
Same battery I have - and will get you some judging points if that matters.
Frankie the Fink is offline
Old 04-15-2019, 03:02 PM
64 Silver Blue
CF Senior Member
I was stumped by the cable colors. I wrapped a bunch of red tape around the end of the black cable, so now I’m happy. Everything is back together and running good.
Old 04-15-2019, 04:07 PM
MikeM
CF Senior Member
The only thing that resembles the OEM battery on that replacement is the location of the +/- posts.
Should be a total deduction. No blue ribbon for you, sonny boy!
MikeM is online now
sidepipe seeker (04-15-2019)
Old 04-15-2019, 05:12 PM
sidepipe seeker
CF Senior Member
My 64 Coupe No A/C has a heat shield spot welded to the battery hold down bracket...according to my NCRS guiding book...that's Factory Correct!...Mark
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
